首页 PLC论坛 PLC论坛
主题:FX2n-4AD模块的使用说明书其中BFM#1—#
点击:4560 回复:1
FX2n-4AD模块的使用说明书其中BFM#1—#4的说明有一段英文如下:Contains the number of samples(1 to 4096) to be used for an averaged result. the default settilg is 8- normal speed. high speed operation can be selected with a value of 1.
#5-#8的说明为:these buffer memories contain the averaged input values for the number of samples entered for the channel in buffer memories #1 to #4 respectively.
这两段我看不懂,请指教。
01-05-14 10:24
模块初始化时的用TO命令向模块写入的值。
01-05-16 07:04
