首页 PLC论坛 PLC论坛
主题:请问一声,s7---200版中的ED,EU???
点击:1692 回复:1
请问一声,s7---200版中的ED,EU在梯形图中怎么表示啊?
我怎么找不到呢 ??
谢谢了
04-09-27 08:42
Instructiont--->Bitlogic-->   -|P|-
Instructiont--->Bitlogic-->   -|N|-
以下是帮助中的材料:
The Positive Transition (EU) contact allows power to flow for one scan for each off-to-on transition.The Negative Transition (ED) contact allows power to flow for one scan for each on-to-off transition.In LAD, the Positive and Negative Transition instructions are represented by contacts.In FBD, the instructions are represented by the P and N boxes.In STL, the Positive Transition contact is represented by the Edge Up instruction. Upon detection of a 0-to-1 transition in the value on the top of the stack, the top of the stack value is set to 1; otherwise, it is set to 0.In STL, the Negative Transition contact is represented by the Edge Down instruction. Upon detection of a 1-to-0 transition in the value on the top of the stack, the top of the stack value is set to 1; otherwise, it is set to 0. For runtime editing (when you edit your program in RUN mode), you must enter a parameter for the Positive Transition and Negative Transition instructions. Refer to Program Edit in RUN Mode for more information about editing in RUN mode.
04-09-27 09:32
