首页 PLC论坛 PLC论坛
主题:现场问题
点击:1032 回复:1
the PG/PC interface that is being used is communicating right now. first close the conections that are still open and then reactivate the connection setup?各位老大谁能帮我解决这个问题?
07-10-06 18:10
PG/PC接口正在交换数据,先将连接断开,然后激活连接设置。
07-10-06 20:30
