诊断内容是:
Event 1 of 10: Event ID 16# 4302
Mode transition from STARTUP to RUN
Startup information:
- Time for time stamp at the last backed up power on
- Single processor operation
Current/last startup type:
- Warm restart triggered via MPI; last power on backed up
Permissibility of certain startup types:
- Manual warm restart permitted
- Automatic warm restart permitted
Last valid operation or setting of automatic startup type at power on:
Previous operating mode: STARTUP (warm restart)
Requested operating mode: RUN
Incoming event
07:08:14:939 am 06/06/94
Event 2 of 10: Event ID 16# 1381
Request for manual warm restart
STOP due to: STOP caused by priority class system
- Startup without modified system configuration
- No difference between setpoint and actual configuration
Requested OB: Startup OB (OB100)
Priority class: 27
Incoming event
07:08:14:938 am 06/06/94
Event 3 of 10: Event ID 16# 4301
Mode transition from STOP to STARTUP
Last valid operation or setting of the automatic startup type at power on:
Previous operating mode: STOP (internal)
Requested operating mode: STARTUP (warm restart)
Incoming event
07:08:14:113 am 06/06/94
我使用Modbus通讯,主从站轮询模式进行数据通讯,出现了上述死机的情况!同时也下载了ob80、ob100等等ob块
