Private Sub Command1_Click()
Text1.Text = "U I t N " + vbCrLf + "220V 71A 15℃ 0r/s" + vbCrLf + "220V 71A 23℃ 60r/s" + vbCrLf + "220V 71A 31℃ 130r/s" + vbCrLf + "220V 71A 37℃ 210r/s" + vbCrLf + "220V 71A 45℃ 260r/s" + vbCrLf + "220V 71A 58℃ 300r/s" + vbCrLf + "220V 71A 65℃ 300r/s"
End Sub
Private Sub Command2_Click()
Shape1.FillColor = &HFF&
Dim U
U = 380
Text1.Text = Text1.Text + vbCrLf + "380V 71A 60℃ 0r/s"
Timer1.Enabled = True
Beep
End Sub
Private Sub Command3_Click()
Text1.Text = Text1.Text + vbCrLf + "220V 100A 70℃ 0r/s"
I = 100
Beep
End Sub
Private Sub Command4_Click()
Text1.Text = Text1.Text + vbCrLf + "220V 71A 80℃ 0r/s"
t = 80
Beep
End Sub
Private Sub Command5_Click()
Text1.Text = Text1.Text + vbCrLf + "220V 71A 60℃ 300r/s"
Beep
End Sub
Private Sub Command6_Click()
Shape1.FillColor = &HFF00&
Text1.Text = Text1.Text + vbCrLf + "220V 100A 70℃ 300r/s"
End Sub
Private Sub Command7_Click()
Text1.Text = Text1.Text + vbCrLf + "0V 0A 50℃ 230r/s" + vbCrLf + "0V 0A 45℃ 160r/s" + vbCrLf + "0V 0A 38℃ 80r/s" + vbCrLf + "0V 0A 30℃ 0r/s" + vbCrLf + "0V 0A 15℃ 0r/s"
End Sub
Public Sub Form_Load()
Dim U As Integer
Dim I As Integer
Dim t As Integer
U = 220
I = 71
t = 60
Timer1.Enabled = False
Command1.Enabled = True
Command2.Enabled = True
Command3.Enabled = True
Command4.Enabled = True
Command5.Enabled = True
Command6.Enabled = True
Command7.Enabled = True
End Sub
Private Sub MMControl1_Done(NotifyCode As Integer)
If Shape1.FillColor = &HFF& Then
MMControl1.Command = "Open"
MMControl1.Command = "Play"
End If
End Sub
Private Sub Timer1_Timer()
If Shape1.FillColor = &HFF& And U > 220 * 1.5 Then
MsgBox "电压过高"
Exit Sub
Else
If I > 85 Then
MsgBox "短路故障"
Exit Sub
Else
If t > 80 Then
MsgBox "温度过高,变压器故障"
Else
MsgBox "警报灯故障"
Exit Sub
End If
End If
End If
End Sub
本来想实现循环查错的,结果只能出现警报灯错误,谁能帮忙??我知道循环放置位置错误,实在因为太菜了,不好意思
