首页 PLC论坛 西门子SIEMENS
主题:求助wincc的安装问题
点击:2930 回复:7
本人安装winccSP3的时候,出现以下提示
MS Security Patch is not installed on this system.
For this WinCC Version, the following software is required:
    WindowsXP SP 2 KB319740
Please run the installation of MS-Security Patch from your MS Tools - CD.
Operation of WinCC under Windows XP SP2 has been released for WinCC clients with deactivated firewall only.
You must deactivate the firewall manually.
本人已经安装好SQLSERVER2000SP3FORWINCC6,请高手告诉我如何进行下一步!
05-12-26 13:44
我也碰到过这个问题,请问你解决了吗?没解决我告诉你怎么解决。ok?
05-12-27 22:18
装WindowsXP SP 2 KB319740补丁
关防火墙
06-01-12 09:35
请问怎样能下载到:WindowsXP SP 2 KB319740补丁
07-08-12 17:14
去网上搜索一下这个补丁就行
07-08-12 22:26
rtrrrrrr
07-08-13 20:44
把“控制面板”的“添加和删除”的“消息队列”安装一下就可以了
MS Tools是WinCC的补丁包
07-09-14 19:41
引用 wanhun112 在 2007-9-14 19:41:00 发言【内容省略】
非常对
07-09-15 08:18
