首页 PLC论坛 西门子SIEMENS
主题:有关WindowsXP SP 2 KB319740
点击:16768 回复:5
好象看到某为人兄也碰到过这个问题,不知道他是怎么解决的,还望 赐教啊
我在各位大侠的指点下安装wincc就差最后一步了,出现如下问题,请各位帮忙啊
MS Security Patch is not installed on this system.
For this WinCC Version, the following software is required:
Please run the installation of MS-Security Patch from your MS Tools - CD.
Operation of WinCC under Windows XP SP2 has been released for WinCC clients with deactivated firewall only.
You must deactivate the firewall manually.
05-12-07 20:40
可以去微软的网站下载,该补丁实质上就是Q319740补丁
05-12-21 09:58
如果你安装了WinXPSP2后,你在你的硬盘上找找,319740,安装一下就可以了。
05-12-22 17:04
能不能具体说一下位置。。。
微软网站好像找不到这个(Q319740)补丁。。。
06-02-04 23:26
该补丁可以在PCS7 6.1的MSTOOL盘中找到
06-02-05 10:49
