首页 PLC论坛 PLC论坛
主题:求助关于西门子S5指示灯含义
点击:536 回复:1
各位坛友好,我公司的老设备最近发生故障,PLC SIEMENS SIMATIC 6ES5524-3UA13模块上有一个红色指示灯常亮(见图),请教是什么故障表示?还有电脑上显示的故障是:
unrecoverable error on the serial communication line.
switch off then switch on the warper by turning the main switch.
in case the error persists,a tech-nical assistance is required.
automatic functioning is not avail-able.
if a warping process has to be carried out,rotate the key-selector towards "emergency" then keep the "broken
end" push-button pressed for about 5 seconds.
盼各位朋友帮我看看,谢谢大家了!
16-04-12 12:15
从字面讲还是挺清楚的,最后一句是讲如何操作的。
16-04-12 13:35
