首页 单片机论坛
主题:时钟和数据恢复
点击:431 回复:0
时钟和数据恢复
Analog Devices, Inc.(简称ADI)为设备设计提供离散速率、多种速率和连续可调的时钟和数据恢复(CDR)集成电路,包括地铁、长距离传输、密集波分复用(DWDM)和光空间通信(FSO)应用。ADI公司的CDR能够轻松集成协议未知的应用,并自动锁定速率在12.3 Mbps~2.7 Gbps的输入数据流,无需参考时钟,同时通过I²C®串行接口报告获得的数据速率。
Part#Results:17
Voltage Supply (V)
Data Rate (Gb/s)
Input Sensitivity (mVp-p)
Jitter Tolerance (Ulpp)
Jitter Transfer
Jitter Gen (mUI rms)
Rate
Reference Clk
Package
Price* (1000-4999)
数据手册DataSheet下载
AD800
-5.5
156
80
.9 UI @ 65 kHz
20-Lead SOIC
$18.90
AD800
AD807
+5
0.155
2
1.0 @ 65 kHz
92 kHz
5
Single
16-Lead SOIC
$11.18
AD807
AD808
+5
0.622
4
0.6 @ 250 kHz
333 kHz
7
Single
16-Lead SOIC
$11.48
AD808
ADN2804
+3.3
0.622
3
1.0 @ 250 kHz
71 kHz @ OC12
1
Single
Optional
5x5 mm LFCSP
$10.00
ADN2804
ADN2805
+3.3
1.25
200
Single
5x5 mm LFCSP
$9.33
ADN2805
ADN2806
+3.3
0.622
200
1.0 @ 250 kHz
71 kHz @ OC12
1
Single
Optional
5x5 mm LFCSP
$9.24
ADN2806
ADN2807
+3.3
0.622
4
1.0 @ 250 kHz
140 kHz @ OC12
1
Multi
X
7x7 mm LFCSP
$11.64
ADN2807
ADN2811
+3.3
2.7
4
1.0 @ 1 MHz
590 kHz @ OC48
2
Single
X
7x7 mm LFCSP
$37.44
ADN2811
ADN2812
+3.3
2.7
6
1.0 @ 1 MHz
490 kHz @ OC48
1
Continuous
Optional
5x5 mm LFCSP
$54.65
ADN2812
ADN2813
+3.3
1.25
6
1UI @ 637 kHz
71 kHz @ OC12
1
Continuous
Optional
5x5 mm LFCSP
$19.73
ADN2813
ADN2814
+3.3
0.675
6
1.0 @ 250 kHz
71 kHz @ OC12
1
Continuous
Optional
5x5 mm LFCSP
$11.64
ADN2814
ADN2815
+3.3
1.25
200
1.0 @ 250 kHz
71 kHz @ OC12
1
Continuous
Optional
5x5 mm LFCSP
$17.76
ADN2815
ADN2816
+3.3
0.675
200
1.0 @ 250 kHz
71 kHz @ OC12
1
Continuous
Optional
5x5 mm LFCSP
$10.47
ADN2816
ADN2817
+3.3
2.7
5
1.0 @ 1 MHz
500 kHz @ OC48
1
Continuous
Optional
5x5 mm LFCSP
$44.26
ADN2817
ADN2818
+3.3
2.7
200
1.0 @ 1 MHz
500 kHz @ OC48
1
Continuous
Optional
5x5 mm LFCSP
$42.05
ADN2818
ADN2819
+3.3
2.7
4
1.0 @ 1 MHz
590 kHz @ OC48
2
Multi
X
7x7 mm LFCSP
$45.54
ADN2819
ADN2865
+3.3
2.7
6
Continuous
Optional
ADN2865
12-08-02 15:02
