首页 单片机论坛
主题:ADSP-21xx处理器
点击:405 回复:0
ADSP-21xx处理器
ADSP-21xx 处理器, 系列处理器是工作频率达160 MHz、功耗电流低到184 μA、代码兼容和引脚兼容的数字信号处理器 (DSP)。21xx系列产品包括适合蜂窝通信应用在Softfone 产品中嵌入的系统芯片(SOC)级集成产品,以及适合电机控制应用的2199x系列产品。21xx系列产品广泛用于从调制解调到工业测试设备多种应用。
Performance
Packaging & Temp Range
Memory
Peripherals
开发工具
 型号
Clock Speed MHz (Max)
External (IO) Supply Voltage
Package
Temp Range
Program RAM Words
Data RAM Word (KWords)
Ext. Memory Bus (Bits)
Timers
Host Port
SPORT
SPI/UART
ADC
评估版
Development Software
(KWords)
ADSP-21990
160
3.3
176 LQFP, 196 CSP_BGA
Industrial
4
4
24
3
Yes
1
Yes
14 bit Dual Ch, 20 MSPS
VisualDSP++
ADSP-21991
160
3.3
Industrial
32
8
24
3
Yes
1
Yes
VisualDSP++
ADSP-21992
160
3.3
Industrial
32
16
24
3
Yes
1
Yes
VisualDSP++
ADSP-2191M
160
3.3
144 LQFP, 144 CSP_BGA
Industrial, Commercial
32
32
16
3
Yes
3
Yes
0
VisualDSP++
ADSP-2196M
160
3.3
8
8
16
3
Yes
3
Yes
0
VisualDSP++
ADSP-2188N
80
1.8, 2.5, 3.3
48
56
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
ADSP-2189N
80
1.8, 2.5, 3.3
32
48
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
ADSP-2187N
80
1.8, 2.5, 3.3
32
32
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
ADSP-2185N
80
1.8, 2.5, 3.3
16
16
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
ADSP-2186N
80
1.8, 2.5, 3.3
8
8
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
ADSP-2184N
80
1.8, 2.5, 3.3
4
4
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
ADSP-2188M
75
2.75, 3.3
48
56
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
ADSP-2189M
75
2.5, 3.3
32
48
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
ADSP-2185M
75
2.5, 3.3
16
16
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
ADSP-2186M
75
2.5, 3.3
8
8
24
1
Yes
2
No
0
ADZS-2189M-EZLITE
VisualDSP++
12-07-19 09:09
