首页 单片机论坛
主题:急求一个关于数据存储的问题
点击:495 回复:0
源程序基本如下:
uchar incept_data[2]={0,0};
uchar i=0;
void main()
   display1();//power on display message
   delay_ms(50);
   display3();//set the parameter display message
init();//permit int0,the beep is work when short current
   while(1)
  if(!parameter)//we must change the message in the (),in order to change mode-->>set?test?
   delay(80);
         init_uart();//transsion message
      current(); //display current
      delay_us(100); //wait AD change,this is must
void display1()//power on display message
void display3()///set the parameter display message
 void dis()//0
  {uchar a;
   switch(incept_data[1])
    case 1://wave
           {lcd_wcom(0x80);
            for(a=0;a<5;a++)
               lcd_wdat(c11[a]);
   delay_us(200);
   break;
 case 2://bias
            {lcd_wcom(0x80+0x0a);
            for(a=10;a<15;a++)
               lcd_wdat(c11[a]);
   delay_us(200);
   break;
    default: ;break;
void wave()//1
   lcd_wcom(0x80+0x05);
      {case 1:lcd_wdat(0x41);break;
    case 2:lcd_wdat(0x42);break;
    case 3:lcd_wdat(0x51);break;
       default:;break;
void bias()//2
     {lcd_wcom(0x80+0x11);
    {case 2:lcd_wdat(0x32);break;
    case 3:lcd_wdat(0x33);break;
          default:;break;
void current()
   {int i;
 char t;
 TEMP_cur(filter());
 lcd_wcom1(0x80+0x5d);
 for(i=0;i<5;i++)
  {t=c3[i];
      lcd_wdat1(t);
//---启动AD转换并读结果///////
 unsigned int ReadAD(void)
  uchar H,L,i;
  uint count;
  cs=0;
  addelay();
  sclk=1;
  sclk=0;
   H=0;
   for(i=0;i<=3;i++)
  sclk=1;
  if(dout) H++;
  sclk=0;
  if(i!=3)
  H<<=1;
L=0;
for(i=0;i<8;i++)
  sclk=1;
if(dout) L++;
  sclk=0;
if(i!=7)
  L<<=1;
   addelay();
cs=1;
count=0;
   count=(unsigned int)(H<<8)|L;
return count;
//////////////////software filter ,average filter///////////////////////////
 unsigned int filter()
//---------------------------this is use the inturrpt to alarm------------------
void init(void)
  IT0=0;
  EA=1;
  EX0=1;
void ist_int0(void) interrupt 0
    delay_us(10);
   if(note==0)
   {alarm();
   delay_us(100);
//-----------------------------this is the intrrupt to receive data-----------------------
 void init_uart(void)
   SCON=0x50;
   TMOD=0x20;
   TL1=0xfa;
   TH1=0xfa;
PCON=0x00;
   TR1=1;
   ES=1;
   EA=1;
void uart(void) interrupt 4
  if(RI==1)
  RI=0;
  incept_data[i]=SBUF;
  i++;
  if(i>1){
   i=0;
  if(i==0)
  switch(incept_data[0])
 case 0xb1:
         dis();break;
    case 0xa1:
      wave();break;
 case 0xa2:
      bias();break;
    default: ;break;
write_add(incept_data[0],0xa0);
   delay_ms(100);
我想把bias();dis();wave()参数分别存放在24C存储器中,不知道read_add 和 write_add放在哪个地方?也就是多个参数的存储与写入,如有朋友能带上参考,万分感谢!
10-11-30 00:21
