首页 自控设计
主题:Glassmaking应用 SMAC音圈电机
点击:627 回复:0
glassmaking应用
smac electric actuators incorporate programmable speeds, positions, and, especially importantly for glass, programmable forces including very low forces on the order of 0.1n or less.smac电动执行机构将可编程速度,位置,尤为重要,也可用于玻璃、可编程的力量包括非常低的力0.1n秩序或更少。smac electric actuators also incorporate a patented soft-land capability, which is very useful when applied to brittle materials.smac电动执行机构也将专利“soft-land”的能力,这是非常有用,当应用于脆材料的精密切割。the force programmability works over the complete stroke, so the same force can be applied through the stroke.可编程的力量作完整的中风,所以相同的力量可以应用通过中风。soft-land incorporates a rapid approach to the working surface followed by a gentle pre-programmed force for final contact.soft-land快速的方法,设计了一种温和,紧随其后的是工作表面的最后的力量管接触。
http://fanyi.youdao.com/img/glass_measuring.gif
measuring thickness of thin flexible glass测量厚度薄灵活的玻璃problem:问题:accuracy of the current air cylinder, lvdt and force control system.目前的准确性,并迫使lvdt气缸控制系统。
solution:解决方案:the customer used the soft-land feature of the smac lal20 in conjunction with a load cell mounted on the rod of the smac actuator.客户使用soft-land smac的特点lal20联同一个传感器安装在smac的杆执行机构。the lal20 is controlled by a dual-axis lac25.lal20控制的dual-axis lac25。
http://fanyi.youdao.com/img/glass-curvature.gif
inspection of the curvature of automotive and aircraft window glass检查汽车和飞机的曲率橱窗玻璃problem:问题:accuracy of the current air cylinder, lvdt and force control system, short life of lvdt, time consuming position calibration.目前的准确性,并迫使lvdt气缸控制系统、寿命短的位置,费时lvdt校准。
solution:解决方案:the two original pneumatic cylinders for centering the windscreen were replaced by two lal95-015 units.,原来两个气缸为以取代了挡风玻璃两lal95-015单位。two of the six pneumatic cylinders for position measurement were not needed anymore.两个六气缸,是不需要的位置测量了。the lal95 provides both positioning and measurement functions.lal95提供的定位和测量功能。all other sensors, mechanical and electronic parts were unchanged. 100% qc/qa in-line inspection now possible during production.其他感测器,机械和电子部件的不变。100%的质量控制和质量保证工作在生产过程中现在可以中期验货。
glass grinding玻璃磨problem:问题:the grinding process produces a 125µm finish with less than a 50µm variation.磨削过程中产生125µm完成还有不到一个50µm变化。damage to glass at the beginning and end of the grind cycle is caused by inadequate force control of the air cylinder driving the grind wheel.玻璃损害的开始和结束不足导致的周期是磨力控制空气的地面全气缸驱动轮中套轮。the force required is from two to four newtons, with a 5mm stroke.从所需要的力二至四牛顿,5毫米中风。
solution:解决方案:customer was able to land softly on the glass panel and provide a constant force using the force mode of the lal55 at both the beginning and end of the stroke.客户能够在玻璃面板轻声地恒力,并提供一个使用“力”模式,同时lal55的开始和结束的行程。
other glassmaking applications其他glassmaking应用
glass cutting玻璃切割
glass scoring for solar panels and lcds玻璃的得分太阳能面板和液晶显示器
chamfering and beveling倒角及斜边
glass de-burring玻璃de-burring
glass manufacturing玻璃制造
glass assembly玻璃装配
car glass manufacturing汽车玻璃制造
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=129714&Name=ytam2007
10-11-26 22:34
