首页 机电一体化
主题:提升链条性能——链条防护知识一:
点击:474 回复:0
问:Why provide protection?      为什么要对进口链条实施防护?
答:Reduce corrosion              减少腐蚀
      Various environments      各种环境
      Improve wear                   提升耐磨
      Reduced corrosion            减少腐蚀
      products in articulating components       连接部件产品
防护方式1、
Lubrication - grease and oil  润滑-油脂及油润
Lowest cost method of protecting chains against corrosion and giving good wear performance.  防止进口链条腐蚀及提高耐磨性能的最经济的方法。
优点:
Simple process        操作简单
No breaking load     不降低破断载荷
reduction                 简化
Low cost                 降低成本
注意:
Regular re-lubrication       定期润滑
Unfit for acidic and alkaline areas, or to operate under water
不适用于酸或碱性环境,或水下操作。
10-05-05 14:53
