#i nclude
#i nclude
typedef unsigned char uchar;
sbit din=p1^0;
sbit clk=p1^1;
sbit load=p1^2;
void send(uchar add,uchar dat) //发送16字节子函数
{ uchar ads,i,j;
load=0;
i=0;
while(i=1;j--)
din=ads&0x80;
ads=ads
main()
send(0x0c,0x01); //初始化max7219
send(0x0b,0x07);
send(0x0a,0xf5);
send(0x09,0xff);
while(1)
send(0x01,0x81); //在八个数码管上显示1-8,带小数点显示
send(0x02,0x82);
send(0x03,0x83);
send(0x04,0x84);
send(0x05,0x85);
send(0x06,0x86);
send(0x07,0x86);
send(0x08,0x88);
max7219驱动程序
#ifndef uchar
#define uchar unsigned char
#endif
#ifndef uint
#define uint unsigned int
#endif
/*max7219寄存器功能说明****************************************/
#define max7219_shutdown 0x0c //0 关闭 1 开启
#define max7219_decodemode 0x09 //0 ndecode all
//1 decode 0
//0f decode 0-3
//ff decode all
#define max7219_intensity 0x0a //亮度控制寄存器 0-f
/*显示位控制寄存器*********************************************/
/*0-第一位 1-第一、二位 ......7-全显示***********************/
#define max7219_scanlimit 0x0b
#define max7219_testreg 0x0f //测试模式 0 普通模式 1显示测试模式
#define max7219_dataaddr 0x01 //显示基址
/*max7219寄存器功能说明结束************************************/
#define max7219_set0(x) x=0
#define max7219_set1(x) x=1
sbit max7219_clk=p1^0;
sbit max7219_load=p1^1;
sbit max7219_din=p1^2;
void max7219_initial()
max7219_set0(max7219_clk);
max7219_set0(max7219_load);
max7219_set0(max7219_din);
void max7219_datasend(uchar addr,uchar data_send) //两个无符号字符型
uchar i,a;
for(i=0;i
addr=addr
此篇文章从博客转发
原文地址:
Http://blog.gkong.com/more.asp?id=75199&Name=sfmcu
