KUKA机器人公司推出具有远伸程的KUKA JET 机器人
2006-05-26 16:44 来源:翻译
Combined 6 Axis and Linear Robot Has Long Reach
更远伸程的6轴向线性机器人
Clinton Township, Michigan — May 25, 2006 – KUKA Robotics Corporation, a leading global manufacturer of industrial robots, today announced the introduction of the KUKA Jet robot, a 6 axis robot mounted on a linear unit. The new robot is designed for customers with applications that entail long reach tasks. The 6 axis robot is mounted either upside down or sideways on the linear rail depending on the application need and is available in four configurations with different reaches and working ranges.
密歇根州克林顿镇525日消息—全球领先的工业机器人生产商KUKA机器人公司今天宣布推出KUKA Jet 机器人,一款可安装于线性装置的6轴机器人。该新款机器人用于客户需要承担较远伸程任务的应用。该6轴机器人可以根据应用需要倒挂式或侧装式安装于直线轨上,并且有四种不同伸缩长度和工作范围的配置。
"Customers with applications where long distances need to be traversed will find the KUKA JET robot ideal," said Kevin Kozuszek, director of marketing for KUKA Robotics Corporation. "The robot combines the speed of a linear axis and the flexibility of a 6-axis robot making it ideal for handling tasks in multiple industries including injection molding, die casting, machine tool manufacturing and logistics."
KUKA机器人公司市场部主管Kevin Kozuszek表示:“那些需要长距离来回移动应用的客户将发现KUKA JET机器人是如此的理想。这款机器人结合了线轴的速度和6轴机器人的灵活性,使得它可以完美地执行多种工业任务,包括注塑成型、冲模铸造、机床生产和物流等行业。”
The KUKA JET robot’s enhanced maneuverability allows machines to be tended through narrow openings and parts precisely positioned even within the machine. It also allows parts to be withdrawn from the machine in a longitudinal direction making it possible to serve a number of machines in a row. Additionally, the installation can be configured to allow several machines to be tended by one combination. The KUKA JET robot is available in four configurations with different reaches and working ranges with payloads ranging from 30 to 60 kilograms.
KUKA JET 机器人增强了的可操作性使得其通过窄小的开放空间就可以对机器操作,并且可以精确地在机器内部安装零件。它还可以纵向地从机器收回零件,从而可以对同一排的数台机器进行提供服务。此外,一个机器人控制几台机器所需要的安装配置情况还可以视情况而定。KUKA JET机器人具有4种不同的伸程和工作范围的配置,负载量从30千克到60千克。
About KUKA
关于KUKA公司
KUKA Robotics Corporation, with its parent company KUKA Roboter GmbH, Augsburg, Germany, is one of the world's leading manufacturers of industrial robots, with an annual production volume approaching 10,000 units, and an installed base of over 60,000 units. The company’s 5 and 6 axis robots range from 3kg to 570kg payloads, and 635mm to 3700mm reach, all controlled from a common PC based controller platform. KUKA robots are utilized in a diverse range of industries including the appliance, automotive, aerospace, consumer goods, logistics, food, pharmaceutical, medical, foundry and plastics industries and in multiple applications including material handling, machine loading, assembly, packaging, palletizing, welding, bending, joining, and surface finishing.
美国KUKA机器人公司是位于德国奥格斯堡市KUKA Roboter 有限公司的子公司,是世界几家顶级工业机器人制造商之一。该公司工业机器人年产量接近1万台,至今已在全球安装了6万台工业机器人。该公司的5轴和6轴机器人负载量从3千克至570千克,机械臂伸程从635毫米到3700毫米,全部由一个普通的基于PC控制器平台控制。KUKA机器人广泛应用在仪器、汽车、航天、消费产品、物流、食品、制药、医学、铸造、塑料等工业上。主要应用于材料处理、机床装料、装配、包装、堆垛、焊接、表面修整等领域。
(本文由中华工控网翻译,转载请注明出处,更多中英对照资料请进异域来风http://world.gkong.com
相关新闻
编辑精选
