艾讯科技发布高亮度17英寸工业TFT LCD显示器及人机界面
2006-04-24 16:07 来源:翻译
AXIOMTEK Releases a High Brightness 17-inch Industrial TFT LCD Monitor with Interface (HMI)
台北
The PANEL6173 features a NEMA4/IP65 compliant front bezel with an ultra slim design. The TFT LCD offers great luminance at 300cd/m² and has a contrast ratio of 500:1. This industrial flat panel monitor supports not only a cost-effective VGA port, but also supports S-video, video, and the even more popular DVI connector. Resistive and capacitive type touchscreens are available, as well as a RS-232 interface. Owing to the screw-type adaptor plug design and 12/24V DC-In support, the PANEL6173 fits in all industrial applications, and with the ultra slim mechanism design, users can easily set the PANEL6173 anywhere.
PANEL6173具有一个超薄设计的NEMA4/IP65通用前面板。该TFT LCD的亮度达到了300cd/m²,对比度是500:1。这个工业平板显示器不但支持合算的VGA接口,还支持S-video, video接口,甚至更受欢迎的DVI连接器。带有电阻和电容式型触摸屏以及RS-232界面。基于其螺旋式的配适器插入设计和支持12/24V 直流电,PANEL6173适用于所有的工业应用,而且因为其超薄的机械设计,用户可以轻易地把PANEL6173安装到任何地方。
The PANEL6173 supports varied mounting methods, including panel, wall, rack mounting or VESA FPMPMI (Video Electronics Standards Association Flat Panel Monitor Physical Mounting Interface) mounting. It is designed to work in a wide range of environments and heavy-duty industrial fields.
PANEL6173支持多种安装方法,包括嵌镶式、壁挂式、支架式或者视频电子标准协会平板显示器物理安装界面式(VESA FPMPMI)安装。其设计可以使其工作于多种环境和重型工业现场之中。
“This ideal large LCD size industrial-grade panel monitor PANEL6173 can be applied to several different industrial or commercial projects, such as transportation, factory automation, and Human Machine Interface,” said Eric Chiang, product manager of the Industrial Automation Department. “Furthermore, AXIOMTEK's industrial flat panel monitors provide highly reliable and highly flexible industrial-grade all-in-one solutions.”
艾讯工业自动化部产品经理Eric Chiang表示:“这个完美的大尺寸LCD工业级别平板显示器PANEL6173可以应用于多种不同的工业或者商业领域,例如运输、工厂自动化以及人机界面等。此外,艾讯的工业平板显示器提供了高可靠性和高灵活性的工业级别一体化解决方案。”
The product will be available in the middle of May.
这款产品将在五月中旬上市。
About AXIOMTEK Co., Ltd.
AXIOMTEK Co., Ltd. is one of the world's leading designers/manufacturers of PC-based industrial computer products. From its roots as a turnkey systems integrator specializing in data acquisition and control systems, AXIOMTEK has mirrored the PC evolution in various industries by shifting its focus toward the design and manufacture of PC-based industrial automation solutions.AXIOMTEK was established since 1990. The company has 210 employees in headquarter and subsidiaries in
关于艾讯
艾讯股份有限公司为一个国际领先的工业计算机系列产品的设计者和制造商。以数据采集和控制为系统组装整合的基础,发展成不同领域之设计与制造的工业自动化解决方案。艾讯股份有限公司成立于1990年,总公司约有210余位员工,更有总计超过80位员工分布在美国、中国、德国和法国等子公司,在全球更有超过60余家的经销商伙伴。艾讯提供工业计算机 (IPC),嵌入式计算机平台(ECP),平板式计算机 (PPC),数据采集解决方案 (DAS),网络设备 (NA),存储设备(SA)备NAS 等超过400种的系列产品。
(本文由中华工控网翻译,转载请注明出处,更多中英对照资料请进异域来风http://world.gkong.com)
