美卡诺外壳表面处理 满足最具挑战性操作环境需求
2019-10-12 09:39 来源:美卡诺元器件(上海)有限公司
If you need more rugged resistance to abrasion, corrosion, or wear in your aluminum housing, we offer a wide range of chemical treatments. Applied prior to priming and painting, they include:
Iriditing
Iriditing offers excellent atmospheric corrosion resistance and is also an excellent primer coat for paint or other organic coatings. This process involves covering the surface of the enclosure with an oxide layer that chemically reacts to form metal chromates. It is most often used to prepare steel, aluminum, and magnesium surfaces. Our standard iriditing material is non-chromium based (Non Hexavalent Chromium), as per RoHS requirements.
Anodizing
This electrolytic passivation process is used to increase the thickness of the natural oxide layer on the surface of metal parts.
