美卡诺 LD1000 线性驱动器——高性能、极耐用
2019-11-14 10:09 来源:美卡诺元器件(上海)有限公司
QQ截图1
Linear drive for demanding applications
The LD1000 linear drive stands out due to its high performance and extremely durable construction. Thanks to its high push and pull forces of up to 10000 N and a maximum stroke length of 1000 mm, it is the ideal solution for demanding applications in the agricultural and off-highway sectors. Its potential areas of application include:
Agricultural and municipal machines: self-propelled harvesters, round balers, transportation vehicles and plant protection equipment
Mobile and stationary applications
Dosing mechanisms: Feed mixing systems
Opening and closing mechanisms: Selection or storage technology
Fast and reliable linear drive with an integrated control system
The LD1000 has a highly resistant housing made of die-cast aluminium with a super robust support tube made of anodised aluminium combined with a stainless-steel stroke pipe. The stroke length range starts from 100 up to 1000 mm. The linear drive features a fast adjustment speed of maximum 100 mm/s. The LD1000 is powered by maintenance-free 12 and 24 volt DC motors, to ensure a maximum of performance and reliability. The integrated control system enables precise adjustment of individual motion profiles and pinpoint positioning.
Use in extreme conditions
Due to having the maximum protection level of IP69K, the linear drive can withstand even extreme environmental conditions. It is not only protected against dust and penetrating water at high pressure but is also heat- and cold-resistant: The linear drive can even withstand temperatures of -20 to +65 degrees Celsius during operation. Moreover, it is unaffected by radiation from the sun. The linear drive is made-to-last thanks to this protective equipment and its durable mechanics. The LD1000 is optionally available with a digital positional feedback system, end stop signals as well as a bus system.
General Features
The LD1000 linear drive is powerful and extremely robust. With a push stroke of 1000 mm and a force of 10,000 N, it is designed for use in agriculture and off-highway applications. The high protection class and the aluminium housing enable usage even in the most extreme conditions. This provides an affordable, maintenance-free alternative to existing drives.
Application areas
All types of mobile outdoor agricultural applications, including agricultural and municipal machinery, self-driving harvesters, round balers, transport vehicles and crop protection equipment.
All types of stationary or mobile dosage mechanisms (e.g. for feed mixing systems).
Closing and opening mechanisms for sorting facilities (e.g. for processing and storage technology).
相关新闻
编辑精选
