BoTouch机箱 - IP65防护!
2018-05-15 09:26 来源:美卡诺元器件(上海)有限公司
IP65 protected BoTouch enclosure for 4.3 "and 10.1" touch screens - enclosure specialist BOPLA presents at this year's embedded world in Nuremberg two new variants of their enclosure series BoTouch. They allow the installation of common 4.3 "and 10.1" capacitive touch display and offer a IP 65 protection. Optimized for embedded applications thanks to its heatsink is the product line FILOTEC.
1
BOPLAs enclosure series BoTouch is very popular thanks to the possible integration of touchscreens and displays. Because of the extremely high dynamics in the display market and the numerous application areas of the touch technology, the series BoTouch been extended to meet all market requirements.
IP65 degree of protection thanks to improved seal
Another important distinguishing feature of the new enclosure variants compared to BoTouch standard series is IP65. Which is realized by means of a foamed-in PU seal and a back plate. The front glas is also glued to the enclosure. As a panel mounted enclosure BoTouch BTK-IP of course also has a foamed-in PU seal in the front frame, which ensures the IP rating 65 towards the electrical panel.
New FILOTEC enclosure allows to insert large format printed circuit cards
At the embedded world BOPLA will show the new size F 1632 of the aluminum profile enclosure for the first time. This simple but at the same high-quality products are mainly used in the area of EPC / IPC application. With the new size BOPLA now meets the requirements of those who want to place even large format printed circuit boards in FILOTEC. The internal dimensions of the enclosure are designed to match the installation of 100 x 160 mm euroboards.
相关新闻
编辑精选
