我们成功的SL4000操作机箱变的更加灵活和模块化
2018-05-15 09:14 来源:美卡诺元器件(上海)有限公司
QQ截图5
For the Aluminum profile enclosure SL 4000 are two additional profiles available as of now. By this do four additional profile combinations arise which make this enclosure to one of the most modular operating enclosures in the market. Thanks to the version variety nearly all established operating- and display panels of the known manufacturers can be integrated into this enclosure.
To support furthermore and to expand constantly our flexibility we have extended the enclosure series SL 4000 by the profiles 5 and 6. The new basic profile 5 contains an installation depth of 55 mm and can be used separately by the connection on the rear side. The combination profile 6 shows an installation depth of 80 mm and can be combined with the profiles 1, 2 and 5.
Our new profile combinations:
Profile 5 + 6    Installation depth 135 mm
Profile 1 + 6    Installation depth 160 mm
Profile 2 + 6    Installation depth 210 mm
Profile 5 + 4    Installation depth 200 mm
By the extension of our profile portfolio we are able to realize 18 possible construction variations which cover an installation depth from 55 mm until 270 mm.
Which operation panel do you use? Please contact us and we will find together the correct profile combination for your requirement.
相关新闻
编辑精选
