全新的具有96K工作内存的ET 200s IM 151-7 CPU正式接受订单
2006-09-05 14:36 来源:西门子(中国)有限公司
    ET 200s IM 151-7 CPU是ET 200s 分布式I/O系统的一部分,具有何S7-314相近的功能,其防护等级为IP20,ET 200s IM 151-7 CPU接口模块是一个"智能预处理单元"(1slave),它能让你实现完美的分布式控制。
    一个具有ET 200s IM 151-7 CPU的ET 200s站点能够控制一个工艺单元,而且也可以用作一个单机CPU,通过连接一个主站接口模块ET 200s IM 151-7 CPU可以作为一个DP主站使用。
    此次发布的ET 200s IM 151-7 CPU进一步增加了工作内存,至此,ET 200s IM 151-7 CPU的工作内存已经从24k增加到了96K,这样,使ET 200s IM 151-7 CPU可以完成更加复杂的控制任务,下述为该产品的技术参数。
技术参数的联接内容如下:
Source of technical data: MM
Voltages and currents
Mains/voltage failure jumpering, min.
5 ms
Load voltage L+
Rated value (DC)
24 V
Short-circuit protection
Yes
reverse polarity protection
Yes
permissible range, lower limit (DC)
20,4 V
permissible range, upper limit (DC)
28,8 V
Current consumption
from supply voltage 1L+, max.
250 mA
Power loss, typ.
3,3 W
Current output to backplane bus (DC 5 V), max.
700 mA
Memory
Memory
RAM
integrated
96 KByte
expandable
No
Load memory
pluggable (MMC)
Yes
pluggable (MMC), max.
8 MByte
Data management on MMC (after last programming), min.
10 Jahr(e)
Backup
present
Yes
CPU/blocks
Number of blocks (total)
1024
DB
Number, max.
511
Size, max.
16 KByte
FB
Number, max.
1024
Size, max.
16 KByte
FC
Number, max.
1024
Size, max.
16 KByte
OB
Size, max.
16 KByte
Number of free cycle OBs
1
Number of time alarm OBs
1
Number of delay alarm OBs
1
Number of watchdog interrupts
1
Number of process alarm OBs
1
Number of startup OBs
1
Number of asynchronous error OBs
6
Nesting depth
per priority class
8
additional within an error OB
4
CPU/processing times
for bit operations, min.
0,1 µs
for word operations, min.
0,2 µs
for fixed point arithmetic, min.
2 µs
for floating point arithmetic, min.
3 µs
Times/counters and their remanence
S7 counter
Number
256
of which remanent without battery
adjustable
Yes
lower limit
0
upper limit
255
Remanence
adjustable
Yes
lower limit
0
upper limit
255
Counting range
adjustable
Yes
lower limit
0
upper limit
999
IEC counter
present
Yes
S7 times
Number
256
adjustable
Yes
lower limit
0
upper limit
255
Remanence
adjustable
Yes
lower limit
0
upper limit
255
Time range
lower limit
10 ms
upper limit
9990 s
IEC timer
present
Yes
Data areas and their remanence
remanent data area in total (incl. times, counters, flags), max.
64 KByte
Flag
Number, max.
256 Byte
Remanence available
Yes
Number of clock memories
8
Data blocks
Number, max.
511
Size, max.
16 KByte
Local data
per priority class, max.
510 Byte
Address area
I/O address area
Inputs
2048 KByte
Outputs
2048 KByte
Process image
Inputs
128 Byte
Outputs
128 Byte
Digital channels
Inputs
16336
Outputs
16336
Inputs, of which central
248
Outputs, of which central
248
Analog channels
Inputs
1021
Outputs
1021
124
124
Time
Clock
Hardware clock (real-time clock)
Yes
Clock / Battery backed and synchronized
Yes
Backup time
6 w
Deviation per day, max.
10 s
Operating hours counter
Number
1
remanent
Yes
Clock synchronization
supports
Yes
to MPI, Master
Yes
to MPI, Slave
Yes
in AS, Master
No
in AS, Slave
No
S7 message functions
Number of login stations for message functions, max.
12
Process diagnostic messages
Yes
simultaneously active Alarm-S blocks, max.
40
Test commissioning functions
Status/control
Status/control variable
Yes
Monitoring functions
Number of variables, max.
30
of which status variable, max.
30
of which control variable, max.
14
Forcing
Forcing
Yes
Test and startup functions / Forcing, number of variables, max.
10
Status block
Yes
Single step
Yes
Number of breakpoints
2
Diagnostic buffer
present
Yes
Number of entries, max.
100
adjustable
No
Communication functions
PG/OP communication
Yes
Global data communication
supported
Yes
Number of GD packets, max.
4
Number of GD packets, transmitter, max.
4
Number of GD packets, receiver, max.
4
Size of GD packets, max.
22 Byte
Size of GD packet (of which consistent), max.
22 Byte
S7 basic communication
supported
Yes
Useful data per job, max.
76 Byte
Useful data per job (of which consistent) max.
76 Byte
S7 communication
supported
Yes
as server
Yes
as client
No
180 Byte
Useful data per job, of which consistent, max.
64 Byte
S5-compatible communication
supported
No
Standard communication (FMS)
supported
No
Number of connections
overall
12
usable for PG communication
11
reserved for PG communication
1
usable for OP communication
11
reserved for OP communication
1
usable for S7 basic communication
10
reserved for S7-Basic communication
0
usable for routing
4
1st interface
isolated
Yes
Stromversorgung an interface (15 to 30 V DC), max.
80 mA
Functionality
MPI
Yes
DP master
No
DP slave
Yes
Point-to-point coupling
No
MPI
12
Services
PG/OP communication
Yes
Routing
Yes
Yes
Yes
S7 communication
Yes
S7 communication, as client
No
S7 communication, as server
Yes
Transmission speeds, max.
12 Mbit/s
DP slave
12
Services
PG/OP communication
Yes
Routing
Yes
No
Yes
direct data exchange (cross traffic)
Yes
DPV1
No
12 Mbit/s
automatic baud rate search
Yes
Transfer memory
Inputs
244 Byte
Outputs
244 Byte
Address area, max.
32
Useful data per address area, max.
32 Byte
2nd interface
isolated
Yes
Functionality
MPI
No
DP master
Yes
No
DP master
Number of connections, max.
12
Services
PG/OP communication
Yes
Routing
Yes
No
Yes
S7 communication
Yes
No
Yes
equidistance support
Yes
SYNC/FREEZE
Yes
Activation/deactivation of DP slaves
Yes
Yes
DPV1
Yes
12 Mbit/s
Number of DP slaves, max.
32
Address area
Inputs, max.
2 KByte
Outputs, max.
2 KByte
Useful data per DP slave
Inputs, max.
244 Byte
Outputs, max.
244 Byte
Isochronous mode
Isochronouos mode
No
CPU/programming
Programming language
STEP 7
Yes
LAD
Yes
FUP
Yes
AWL
Yes
SCL
Yes
GRAPH
Yes
Nesting levels
8
User program protection/password protection
Yes
Cycle time monitoring
lower limit
1 ms
upper limit
6000 ms
adjustable
Yes
preset
150 ms
Isolation
between load voltage and all other switching components
Yes
between PROFIBUS DP all all other circuits
Yes
Dimensions and weight
Width
60 mm
Height
119,5 mm
Depth
75 mm
Weights
Weight, approx.
200 g
相关新闻
编辑精选
