英特尔G41芯片组ATX主板SYM76941VGGA即将上市
2011-10-02 16:33 来源:杭州东田科技有限公司
    艾讯宏达即将推出一款采用英特尔G41芯片组的ATX主板SYM76941VGGA。
    SYM76941VGGA采用Socket   LGA775架构,支持英特尔酷睿4核/酷睿2双核/奔腾D/赛扬D处理器。采用英特尔G41+ICH7(或ICH7R)芯片组,最大支持8GB DDR3 内存。集成2个英特尔82574E PCI-E千兆网络控制器,6个RS232串口,8个USB2.0接口;支持1 个 PCI-EX16, 1个 PCI-EX1, 5 个 PCI扩展槽。
详细规格:
>> System
Processor                             Socekt LGA775 Support Core 2 Quad Q9000 Series/Core 2 Duo/ Pentium D/Celeron D
Chipset                                Intel G41 + ICH7/ ICH7R(option by MOQ), FSB 800/1066/1333MHz
DRAM                                  2 x 240PIN DIMM DDR3 800/1066 max up to 8GB
BIOS                                        8Mb AMI Flash ROM
Power Supply                       1 x 24Pin ATX power connector, support AT/ATX mode
Watchdog                                 Watchdog timer function (Reset: 1~65535 level)
Dimension                                 305mm x 244mm
>> I/O Ports
HDD                                    4 x SATA-300 Interface, support RAID 0/1/5/10(ICH7R)
FDD                                 1 x FDD port
Serial Port                                6 x RS232 COM ports
Parallel                                 1 x Parallel pin-header
Audio                                  Realtek ALC662 HD audio codec, support 5.1CH audio
Keyboard/Mouse                   2 x PS/2 for Keyboard and Mouse
LAN                                     2 x Intel 82574L PCI-E Gigabit Lan
USB                                     8 x USB2.0 (4 by onboard header)
Digital I/O                            4 input; 4 output
Expansion                            1 x PCIeX16, 1 x PCIeX1, 5 x PCI slots Expansion
>> Display
Graphics                               Intel GMA X4500, Max. shared system memory up to 1759MB
VGA                                    2048 x 1536 maximum resolution
DVI                                     2048 x 1536 maximum resolution
>> Environment
Operation Temperature          0°~60°C
Humidity                              10~90%
SYM76941VGGA主板具备高性价比特点,即将量产,敬请期待!
编辑精选
