![]() BCM is proud to introduce the RX965Q MicroATX motherboard, powered by Intel® Q965 Express chipset and Intel® Core8482;2 Duo processor up to 1066 MHz. Accommodating up to 8 GB of Dual Channel DDR2 800 SDRAM, RX965Q offers a powerful platform to system developers. It deploys a more responsive, high-performance and low-power system, which is ideal for highly interactive gaming, KIOSK, Point of Service, industrial control & automation, digital security surveillance, as well as medical imaging applications.
Superior graphics & memory The Intel® Q965 Express chipset is designed to optimize support for Intel® Core8482;2 processors, empowering RX965Q to fulfill the most demanding Graphics requirements for gaming applications. The RX965Q makes the most of the FMA (Fast Memory Access) feature built into the Q965 chipset; FMA helps to improve system performance, automatically optimizing available memory bandwidths, thus reducing the latency of memory access. The RX965Q applies Intel® Graphics Media Accelerator 3000 (GMA 3000) technology that supports DirectX 9.0c, Pixel Shader 2.0, 256 MB of video memory, and dual independent display through ADD2 and MEC cards. The GMA 3000 feature improves game-play performance, enables greater realism, and offers easier access, greater stability, lower power consumption, and supplies a more cost effective solution.
High-speed expansion & connections One onboard PCI Express x16 slot supports the latest high-performance graphics cards with a bus bandwidth 4 times higher than a regular AGP 8X interface. One PCI Express x4 bus also outperforms the standard PCI interface with its exceptionally high bandwidth up to 2.0 GB/s. Other high-speed features include six Serial ATA connectors (300MB/s) for high-speed hard disk drives, eight USB 2.0 ports for 480 Mbps data transfer fate, one PCI Express-based 10/100/1000 Ethernet port, and 8-channel High Definition Audio.
A ready platform for embedded systems Dual-core processing is the latest innovation in microprocessor technology. The Intel® Q965 Express chipset supports key requirements for many embedded computing designs, including memory performance, graphics, manageability, responsiveness, noise reduction and data protection. Combining all the best features of Intel® Q965 chipset and Core8482;2 processor, the RX965Q motherboard opens a whole new horizon for serious system players: now it is possible to achieve a new competitive strength to stay on top of business.
Features .Supports Intel® Pentium® D / Pentium® 4 / Celeron®/ Core 2 Duo CPU .Intel® Q965 Chipset .Four DIMMs up to 8 GB Dual Channel DDR2 800 / 667 / 533 SDRAM .Intel Graphics Media Accelerator 3000 .AD1988 8-channel High Definition Audio .Intel® 82566DM PCI-E Gigabit LAN .1 PCI-E x16, 1 PCI-E x4, 2 PCI .1 COM, 10 USB 2.0, 6 SATA
About BCM BCM is a global supplier of motherboard and single board computer products for the industrial, OEM/ODM and embedded PC industry. We specialize in providing custom and off-the-shelf motherboards with an emphasis on long lifecycle, customization, revision-control, design support, and offer far greater flexibility and value when compared to other embedded board manufacturers.
