首页 PLC论坛 PLC论坛
主题:WINCC安装问题,KB319740哪里有,急求!
点击:2190 回复:0
好象看到某为人兄也碰到过这个问题,不知道他是怎么解决的,还望 赐教啊
我在各位大侠的指点下安装wincc就差最后一步了,出现如下问题,请各位帮忙啊
MS Security Patch is not installed on this system.
For this WinCC Version, the following software is required:
    WindowsXP SP 2 KB319740
Please run the installation of MS-Security Patch from your MS Tools - CD.
Operation of WinCC under Windows XP SP2 has been released for WinCC clients with deactivated firewall only.
You must deactivate the firewall manually.
05-12-24 11:36
