首页 PLC论坛 PLC论坛
主题:小弟新学PLC 这是PLC300的OB1块中的程序,能帮我解释下吗?谢谢!!
点击:826 回复:0
CALL  "SWR_ZYK" , DB5             // Call of FB 101 'SWR_ZYK' with instance DB
      DB_WORK_NO   :=DB1               // Work DB for SWR
      CALL_POSITION:=TRUE              // Call_Position = TRUE at begin of redundant program
      RETURN_VAL   :=MW6               // Block return value
      EXT_INFO     :=MW8               // Extended information
     A     DB5.DBX    9.1              // Check if station is Master
     JC    END
//redundant user program
     CALL  "AI1"
     CALL  "AO1"
END:  NOP   0
      CALL_POSITION:=FALSE             // Call_Position = FALSE at END of redundant program
      RETURN_VAL   :=MW10              // Block return value
      EXT_INFO     :=MW12              // Extended information
08-05-23 13:44
