西门子将MindSphere引入微软Azure云平台
2016-11-28 10:58 来源:翻译
Siemens to bring MindSphere to Microsoft Azure cloud platform
Siemens announced plans to make its open IoT ecosystem MindSphere available on Microsoft’s Azure cloud platform during the course of 2017. MindSphere enables industrial enterprises to improve the efficiency of plants through the acquisition and analysis of large quantities of production data. The two companies plan to offer the MindSphere platform and affiliated apps on the Azure cloud platform in the future. The use of public cloud services means cutting out the installation and maintenance work involved in creating a dedicated IT infrastructure. In addition, Azure infrastructure services enable availability on a scalable basis, as only the actually required computing power is used and charged for. NET support reduces the effort involved in developing new MindSphere apps for programmers.
西门子宣布计划在2017年期间在微软的Azure云平台提供其开放的物联网生态系统MindSphere。MindSphere使工业企业能够通过收集和分析大量生产数据来提高工厂的效率。两家公司计划未来在Azure云平台上提供MindSphere平台和关联应用程序。使用公有云服务意味着可以从搭建专用IT基础架构涉及的安装和维护工作抽身开来。此外,Azure基础架构服务在可扩展的基础上实现可用性,因为只用到实际所需的计算能力和支付.NET支持费用,减少了程序员开发新的MindSphere应用程序所需的工作量。
As part of the collaboration, Siemens customers aiming to develop and make available their apps in the public cloud will be able to choose in future between Microsoft datacenters in different locations around the world. With Azure Stack, the aim is for them to also utilize Azure services within their own datacenter: They will benefit from the scalability and efficient management of a public cloud solution without compromising the scope for control offered by their own datacenter.
作为合作的一部分,有意在公有云开发和提供应用程序的西门子客户,未来将可以选择微软在全球不同地方的数据中心。通过Azure Stack,他们的目标也是在自己的数据中心内部利用Azure服务:他们将受益于公有云解决方案的可扩展性和高效管理,而不会影响自家数据中心所覆盖的控制范围。
In addition to Java, JavaScript and Python, plans are in place for MindSphere to also support .NET applications in the future, which will allow .NET developers to benefit from existing applications and expertise when developing new MindSphere apps.
除了Java、JavaScript和Python之外,MindSphere还计划在未来支持.NET应用程序,这将使得.NET开发人员在开发新的MindSphere应用程序时从现有应用程序和专业知识中受益。
MindSphere is designed as an open IoT ecosystem. It can be used by industrial enterprises as the basis for their own digital services, in fields such as predictive maintenance, energy data management or resource optimization. Machine and plant engineering companies in particular can use the platform to monitor machine fleets distributed around the world for servicing purposes, to reduce standstill periods and so offer new business models. MindSphere also provides the foundation for data- based services from Siemens such as predictive maintenance of machine tools (Machine Tool Analytics) or integrated drive systems (Drive Train Analytics).
MindSphere是一个开放的物联网生态系统。在预测性维护、能量数据管理或资源优化等方面,工业企业可以将其作为自己数字服务的基础。尤其是机器和工厂工程公司可以使用该平台来监视遍布世界各地的机群用于维护,以减少停机时间并因此提供新的商业模式。 MindSphere还为西门子基于数据的服务提供了基础,如机床(Machine Tool Analytics)或集成驱动系统(Drive Train Analytics)的预测性维护。
Microsoft and Siemens have worked together to support communication standards in industry for many years. Within the scope of the SPS IPC Drives from November 22 – 24, 2016 in Nuremberg, Microsoft will be present in the Siemens MindSphere Lounge showcasing services to facilitate the work of app developers designing solutions for the MindSphere platform.
微软和西门子一起携手支持工业通信标准多年。2016年11月22至24日在纽伦堡举办的SPS IPC Drives展会上,微软将出席西门子MindSphere Lounge展示服务,以方便应用开发人员为MindSphere平台设计解决方案。
相关新闻
编辑精选
