艾默生为法国能源回收厂提供自动化系统
2007-11-28 16:16 来源:翻译
Emerson to automate energy recovery plant for Syctom in France
艾默生为法国Syctom能源回收厂提供自动化系统
AUSTIN, TEXAS , November 24, 2007 -- Emerson Process Management has been awarded a contract to digitally automate one of Europe's most innovative recycling and energy recovery plants being built by Syctom on the banks of the River Seine in Paris. Emerson will install PlantWeb digital plant architecture with FOUNDATION fieldbus technology for the major project that will recycle refuse from 1.1 million Paris residents, converting the waste into energy.
奥斯汀11月24日消息——艾默生过程管理获得一份合约,以数位化的自动化,为Syctom正在巴黎塞纳河岸兴建的欧洲最有创新的循环能源回收工厂之一提供数字化自动化系统。艾默生将为该重大项目安装PlantWeb数字工厂架构与基金会现场总线技术,该工厂将从110万巴黎居民回收的垃圾,把其转化为能源。
Syctom recognized the value of Emerson's knowledge and experience gained from similar large capital projects and awarded the contract following a rigorous vetting procedure. Emerson's PlantWeb digital plant architecture met Syctom's vision to install the most modern automation and control system available today. The cost and time savings that PlantWeb provides during installation, and the operational benefits that are enabled, made it the first choice for this high profile installation.
Syctom认可艾默生的技术和其类似大型资本项目经验的价值,并经过严格的审批程序后授予了这份合约。艾默生的PlantWeb数字工厂架构符合Syctom安装当今最先进的自动化及控制系统的理念。PlantWeb安装过程中所带来的成本及时间节省,以及运作好处使其成为这个高额安装项目的第一选择。
The project has been designed to be a technological showcase with special consideration being given to integrating the building into the surrounding environment. Two thirds of the building will be underground to minimize the impact on the local community and there will be no steam plume or chimneys. In addition, no industrial water will be discharged into the Seine.
该项目被设计为一个技术展示,特别考虑到与周边环境的整合。回收厂三分之二的建设将在地下,以减少对当地社区的影响,也就是将没有蒸汽柱或烟囱。此外,没有任何工业用水将排入塞纳河。
"There have been many environmental issues to be addressed, in particular the sensitive area of emissions," said Dominique Coutart, Project Director, Syctom. "Emerson's PlantWeb architecture and the innovative design of the plant will ensure that emissions will be significantly lower than the stringent levels required by the latest European regulations."
Syctom项目主管Dominique Coutart表示:"有很多环保问题有待解决,特别是敏感地区的排放量。艾默生公司的PlantWeb工厂架构及创新设计的处理厂将确保排放量将大大低于最新欧洲条令要求的严格级别。"
Emerson's Rosemount Analytical instruments will be used for the continuous monitoring of the emissions to ensure that the plant meets all the required criteria, this includes levels for dioxins, cadmium and sulphur dioxide.Sophisticated treatment equipment will guarantee that smoke emissions will be less than 50% of the European limit.
艾默生的Rosemount分析仪器将被用于连续监测排放量情况,以确保回收厂符合所有规定的标准,这包括各级二恶英、镉和二氧化硫。先进的处理设备将保证烟气排放量将少于欧洲极限的百分之五十。
"This is a highly imaginative scheme that uses the best technologies to recover and recycle waste in a sensitive and densely populated area," said David Dunbar, president of Emerson Process Management in Europe. "Emerson's class leading technologies have been specified for the critical continuous monitoring of the emissions and we are delighted that Syctom has recognized the benefits that Emerson's PlantWeb based control and automation will provide during installation and later, when the plant is fully operational."
艾默生过程管理欧洲区总裁David Dunbar表示:"这是一个非常富有想象力的计划,即用最好的技术在敏感而人口稠密的地区回收及循环再造废物。艾默生的顶级领先技术已指定为排放量的关键连续监测,而我们很高兴Syctom已经认识到艾默生基于PlantWeb的控制和自动化系统在安装期间和当工厂全面投入运作之后将带来的利益。"
The installation is based on Emerson's PlantWeb digital plant architecture, with a DeltaV digital control system and FOUNDATION fieldbus communications technology with 65 segments and over 500 intelligent devices from several vendors. These include Rosemount pressure, flow, level and temperature instruments, and Fisher control valves with Fisher FIELDVUE digital valve controllers as well as the Rosemount Analytical analysers.
该装置是基于艾默生的PlantWeb数字工厂架构,连同DeltaV数字控制系统和基金会现场总线通信技术和65个部分,以及来多数家供应商的500多个智能设备。这些包括Rosemount压力、流量、水平和温度仪器仪表,以及Fisher控制阀和Fisher FIELDVUE数字阀控制器,还有Rosemount Analytical分析仪。
By using a solution based on FOUNDATION fieldbus, it has been possible to significantly reduce the space required for the control room footprint, thereby freeing this space for other uses. For example, a conventional wired system would have required up to 30 control cabinets but this will be reduced to just five with the simplified wiring and reduced hardware required by the FOUNDATION fieldbus network.
通过利用一个基于基金会现场总线技术的解决方案,它有可能大大减少控制室面积所需的空间,从而为其他用途腾出空间。举例来说,传统的有线系统将需要多达30个控制柜,但这样将减少到只有5个,并简化了布线和减少了基金会现场总线网络所需的硬件。
Emerson will also be providing AMST Suite: Intelligent Device Manager predictive maintenance software, which will give operators data from the FOUNDATION fieldbus devices on the network. AMS Device Manager will make configuration and commissioning of the devices easier, contributing to faster start up of the plant. When the plant is operational, AMS Device Manager will provide online access to instrument and valve diagnostics allowing problems to be resolved before they affect plant operations.
艾默生还将提供AMST套件:智能设备管理器预测维护软件,这将给运营商提供来自网络上基金会现场总线设备的数据。 AMS设备管理器将更容易睇配置与调试设备,有助于更快地启动处理厂。一旦处理厂开始运营, AMS设备管理器将提供在线查阅仪表和阀门诊断,让问题在影响到处理厂运作之前得到解决。
Replacing an existing plant, the new facility will be constructed at Issy Les Moulineaux in the suburbs of Paris and will recover and sort the domestic rubbish from 1.1 million residents. It has the annual capacity to convert 460,000 tons of domestic waste into energy as well as being able to sort and recycle 55,000 tons of domestic packaging and large objects.
取代现有处理厂的新厂将建在巴黎郊区的Issy Les Moulineaux,将回收和分拣来自110万居民的家居垃圾。每年,它可以将46万吨的家居废物转化为能源,还能够分类和回收5万5千吨家居包装品和大型物件。
About Emerson Process Management
关于艾默生过程管理
Emerson Process Management, an Emerson business, is a leader in helping businesses automate their production, processing and distribution in the chemical, oil and gas, refining, pulp and paper, power, water and wastewater treatment, food and beverage, life sciences and other industries. The company combines superior products and technology with industry-specific engineering, consulting, project management and maintenance services. Emerson brands include PlantWeb, Fisher, Micro Motion, Rosemount, Mobrey, Daniel, Bristol, DeltaV, Ovation, and AMS Suite.
作为艾默生集团的业务之一,艾默生过程管理为工业生产、加工、分销提供自动化服务,应用在化工、石油天然气、精炼、纸浆和造纸、能源、食品饮料、医药等领域。艾默生过程管理将先进的产品和技术结合在为不同工业而设计的工程、咨询、项目管理和维护服务中。艾默生过程管理旗下的品牌有:PlantWeb, Micro Motion, Fisher, Rosemount, Mobrey, Daniel, Bristol, DeltaV, Ovation, 以及 AMS 套件。
About Emerson
关于艾默生
Emerson, based in St. Louis, is a global leader in bringing technology and engineering together to provide innovative solutions to customers through its network power, process management, industrial automation, climate technologies, and appliance and tools businesses. Sales in fiscal 2007 were $22.6 billion.
总部位于圣路易斯市的艾默生是一家全球领先的公司,该公司将技术与工程相结合,在网络能源、过程管理、工业自动化、环境优化技术及家电和工具等领域为客户提供创新性的解决方案。公司2007 财年的销售额达226亿美元。
(本文由中华工控网翻译,转载请注明出处,更多中英对照资料请进异域来风http://world.gkong.com)
