首页 PC Based IPC 工控机 PC Based IPC 工控机
主题:请看一款RADISYS新出的主板,请帮我分析这个板子该在哪个行业进行销售。
点击:1428 回复:0
FEATURE SUMMARY
Mini-ITX form factor
Intel® Core™ Duo, Celeron® M, LV and ULV processors
Intel® 945GM Express chipset
667/533MHz Front-Side Bus
Two DIMM sockets
Up to 4GB DDR2-667 memory
Dual-Channel memory
Intel® GMA950 Graphics
x16 PCI Express graphics slot
18-bit, dual channel LVDS
TV-out header
VGA output
Dual independent displays
Intel® High Definition Audio
Eight channel CODEC for 7.1 audio
S/PDIF digital audio output
Mini-PCI Type lllA socket
PCMCIA Type II socket
Compact Flash Type I socket
Single or dual Gigabit Ethernet
Eight USB 2.0 ports
Four RS-232 serial ports
PS/2 keyboard and mouse ports
IrDA interface
Two SATA 1.5 Gbps ports
One Ultra ATA100 port
Phoenix TrustedCore™ BIOS
TPM 1.2 header
System monitoring
Automatic fan speed control
GPIO port
ACPI 3.0
RoHS compliant
集成视频输出,7.1声道输出,945芯片组,P4双盒。。。。。
我想知道这个扳子在国内应该在什么地方用。。。。
北京泽锦联控科技有限公司 www.inio.com.cn msn:pcbeijing@hotmail.com.cn
Form Factor Size Mini-ITX motherboard, 6.7” x 6.7”, 170mm x 170mm, 10-layer PCB
Processor Type Supports Intel® Core Duo™ and Celeron® M, LV, and ULV processors
Socket PGA-478 CPU socket and support for BGA-479 CPUs
FSB 667MHz and 533MHz system bus
Chipset Type Intel® 945GM Express chipset with Intel® ICH7M
Memory Type Two sockets for DDR2-667, DDR2-553 and DDR2-400 DIMM modules
Capacity Up to 4GB of system memory (3.2GB approx available for system memory)
Performance Dual-Channel memory support
Video Type Intel® Graphics Media Accelerator 950 integrated video
Supports dual independent video outputs
Resolution VGA: 2048 x 1536 at 75Hz and 32-bit color, LVDS: 1600 x 1200
Graphics Acceleration x16 PCI Express graphics slot with support for Media Expansion Cards (ADD2+)
Video Outputs VGA, 18-bit dual channel LVDS, TV output header
TV Output Header for Composite, Component and S-Video outputs
Audio Type Intel® High Definition Audio using Sigmatel STAC9220 eight channel CODEC
Connectors 6 audio jacks for 7.1 surround sound
On-board CD-ROM audio input header
Ethernet Controller Single or dual Broadcom BCM5789 Gigabit Ethernet controllers
Expansion PCI Express x16 PCI Express graphics slot – supports x1 PCI Express cards
PCI Mini-PCI Type lllA card socket
CompactFlash Type l socket
Power Management ACPI ACPI 3.0 supporting states S0, S3 (suspend to RAM), S4 and S5
System Management System Monitoring Voltage, temperature and fan monitoring (3 fans)
Lithium cell voltage monitoring
Automatic fanspeed control based on thermal monitoring
Watchdog Programmable watchdog timer
SMbus SMbus header
Power Supply Type Support for hard- and soft- switched power supplies
Connector Standard 24-pin ATX power supply connector with an additional 4-pin ATX 12V connector
Battery  Lilthium coin cell (5 years operating life typical)
BIOS  Phoenix BIOS TrustedCore™ - includes network boot and PXE
Customizable logo and BIOS settings
I/O USB Eight USB 2.0 ports – four on rear I/O panel and four on headers
GPIO 13-bit General Purpose I/O header with an additional PWM signal
Serial Ports Four RS232 serial ports – two on rear I/O panel and two on headers
IrDA IrDA compliant infrared interface with support for SIR and ASK
Disks SATA Two SATA 1.5Gbps ports
IDE One Ultra ATA100 interface with 44-way slim type header
Security TPM Header connector for a Trusted Platform Module (TPM) 1.2
Drivers Operating Systems Windows XP, Windows XPe, Windows Vista, Linux
Safety Compliance  Evaluated in accordance with UL60950, EN60950 and IEC60950
EMC Compliance  Evaluated in accordance with EN55022, EN55024 and FCC Part 15 Class B
Environment Operating Temp. 0°C to 70°C
Storage Temp. -40°C to 85°C
Relative Humidity 5% to 95% non-condensing
