首页 PLC论坛 西门子SIEMENS
主题:西门子plc中命令 fr用在什么情况下,那个说明看不懂
点击:1672 回复:3
西门子plc中命令fr用在什么情况下,那个说明看不懂
06-11-27 22:02
不明白你说的啥意思
06-11-28 13:18
我也不明白说得什么意思!?
06-11-28 15:01
When RLO transitions from "0" to "1", FR clears the edge-detecting flag that is used for setting and selecting upwards or downwards count of the addressed counter. Enable counter is not required to set a counter or for normal counting This means that in spite of a constant RLO of 1 for the Set Counter Preset Value, Counter Up, or Counter Down, these instructions are not executed again after the enable.
允许指令(FR)只有在逻辑操作结果(RLO)由0跳变为1时,才对计数器进行允许操作.CPU只在正边沿信号时执行FR指令.
例子:
STL Explanation
A I 2.0 //检查输入 I 2.0的信号状态.
FR C3 //当A 2.0信号状态从0变为1的时候启用计数器 C3
06-11-28 19:19
