首页 单片机论坛
主题:我的程序不能编译,错在哪里啊。急
点击:1835 回复:1
#include
#include
#include
#define uint unsigned int
#define uchar unsigned char
#define TRUE    1
#define FALSE   0
#define ADC0804 XBYTE[0X9FFF]
#define DAC0832A XBYTE[0X3FFF]
#define DAC0832B XBYTE[0X5FFF]
#define DAC0832C XBYTE[0X7FFF]
#define P2764 CODE[0X1FFF]
#define x DBYTE[0X40]
sbit add0=P3^4;
sbit sub0=P3^5;
sbit A_M=P1^3;
sbit P1_4=P1^4;
sbit chanl=P3^2;
sbit SCL=P1^0;
sbit SAD=P1^1;
sbit P1_2=P1^2;
sbit PSW_5=PSW^5;
sbit PSW_1=PSW^1;
uchar *xp,i;
code uchar TAB[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar outdata, indata ,iout;
uchar kdu;
delay(int t)
{int m;
P1_2=!P1_2;
for(m=0;m  {;}
void display(void)       /*循环显示子程序*/
uchar j;
for(j=0;j<5;j++)
 if(i==0||i==5||i==10)                //亮绿色自动运行指示灯
  SBUF=TAB[*(xp+i+j)]|0x80;
  else
  SBUF=TAB[*(xp+i+j)];   /*将数据传输到串口寄存器*/
  while(TI==0);          /*串口发送数据,没发送完,等待*/
  TI=0;
void start_e2rom(void)           /*启动 E2ROM */
data char j;
for(j=1;j<10;j++) {j=j+j;};
SCL=0;
SAD=1;
SCL=1;
SAD=0;
SCL=0;
void end_e2rom(void)            //关断E2ROM
data char j;
SCL=0;
SAD=0;
SCL=1;
SAD=1;
SCL=0;
uchar read_one_e2rom(void)
data char i,j;
uchar ret_value,temp;
SAD=1;
temp=0x80;
ret_value=0;
for(i=0;i<8;i++)
SCL=0;
SCL=1;
if(SAD==1)
ret_value=ret_value+temp;
temp=temp>>1;
SCL=0;
SCL=1;
SCL=0;
return ret_value;
void write_one_e2rom(uchar one_ch)
data char j;
for(j=0;j<8;j++)
SCL=0;
if(one_ch>=0x80)
SAD=1;
else SAD=0;
SCL=1;
one_ch=one_ch<<1;
SCL=0;
SCL=1;
/* while (SAD==1); */
SCL=0;
uchar read_char(uint address)
uchar con;      /* first control byte to  E2ROM */
con=0xa0;
start_e2rom(); /*initition and start E2ROM */
write_one_e2rom(con); /* send control byte write */
write_one_e2rom( (uchar)(address&0x0ff) );      /* send word address */
start_e2rom();
write_one_e2rom(con+1); /* send control byte  read*/
con=read_one_e2rom();     /* read one charater */
end_e2rom();
return con;
void write_char(uint address,uchar val)
con=0xa0;
write_one_e2rom(con); /* send control byte */
write_one_e2rom( (uchar)(address & 0xff) );      /* send word address */
write_one_e2rom(val);    /* write one charater */
end_e2rom();
delay(120);
return;
uchar read_string(uint address,uchar len,uchar *pnt)
uchar i_r;
for(i_r=0;i_r {
*pnt=read_char(address+i_r);     /* read one charater */
pnt=pnt+1;
return TRUE;
uchar write_string(uint address,uchar len,uchar *pnt)
uchar *tmp_pnt;  /* temporal pointer */
uchar ret_v;     /* read value */
uchar i_w;
tmp_pnt=pnt;
for(i_w=0;i_w {
write_char(address+i_w,*tmp_pnt);
tmp_pnt=tmp_pnt+1;
tmp_pnt=pnt;
for(i_w=0;i_w {
ret_v=read_char(address+i_w);
if(ret_v!=*tmp_pnt)
return FALSE;
tmp_pnt=tmp_pnt+1;
return TRUE;
 void dream (void)             //       蒸汽子程序
   uint temp;
  temp=99*(indata-50);
  temp=temp/75;
  kdu=99-temp;
  temp=16*kdu;
  temp=temp/99;
  iout=temp+4;
  temp=200*kdu;
  temp=temp/99;
  outdata=temp+50;
  DAC0832A=outdata;
  DAC0832B=50;
  DAC0832C=50;
   *xp=1;
   *(xp+1)=kdu/10;
   *(xp+2)=kdu%10;
   *(xp+3)=iout/10;
   *(xp+4)=iout%10;
   *(xp+5)=2;
   *(xp+6)=0;
   *(xp+7)=0;
  *(xp+8)=0;
   *(xp+9)=4;
   *(xp+10)=3;
   *(xp+11)=0;
   *(xp+12)=0;
   *(xp+13)=0;
   *(xp+14)=4;
     void coolwater1(void)               //表冷1子程序
   uint temp;
  temp=99*(indata-150);
  temp=temp/50;
  kdu=temp;
  temp=8*kdu;
  temp=temp/99;
  iout=temp+4;
  temp=100*kdu;
  temp=temp/99;
  outdata=temp+50;
  DAC0832A=50;
  DAC0832B=outdata;
  DAC0832C=50;
   *xp=1;
   *(xp+1)=0;
   *(xp+2)=0;
   *(xp+3)=0;
   *(xp+4)=4;
   *(xp+5)=2;
   *(xp+6)=kdu/10;
   *(xp+7)=kdu%10;
  *(xp+8)=iout/10;
   *(xp+9)=iout%10;
   *(xp+10)=3;
   *(xp+11)=0;
   *(xp+12)=0;
   *(xp+13)=0;
   *(xp+14)=4;
   void coolwater2(void)                   //表冷2子程序
  uint temp;
  temp=99*(indata-200);
  temp=temp/50;
  kdu=temp;
  temp=8*kdu;
  temp=temp/99;
  iout=temp+4;
  temp=100*kdu;
  temp=temp/99;
  outdata=temp+150;
  DAC0832A=50;
  DAC0832B=250;
  DAC0832C=outdata;
   *xp=1;
   *(xp+1)=0;
   *(xp+2)=0;
   *(xp+3)=0;
   *(xp+4)=4;
   *(xp+5)=2;
   *(xp+6)=9;
   *(xp+7)=9;
  *(xp+8)=1;
   *(xp+9)=2;
   *(xp+10)=3;
   *(xp+11)=kdu/10;
   *(xp+12)=kdu%10;
   *(xp+13)=iout/10;
   *(xp+14)=iout%10;
     void newflow(void)                               //新风子程序
   DAC0832A=50;
   DAC0832B=50;
   DAC0832C=50;
   *xp=1;
   *(xp+1)=0;
   *(xp+2)=0;
   *(xp+3)=0;
   *(xp+4)=4;
   *(xp+5)=2;
   *(xp+6)=0;
   *(xp+7)=0;
  *(xp+8)=0;
   *(xp+9)=4;
   *(xp+10)=3;
   *(xp+11)=0;
   *(xp+12)=0;
   *(xp+13)=0;
   *(xp+14)=4;
       void sdadd(void)interrupt 1          //定义一个中断服务开度加子程序
             if(kdu==99);     //判断开度等于99,不增加
             else
             kdu+=1;               //开度值加一
     sd_display();        //手动状态显示
      void sdsub(void)interrupt 3             //定义一个中断服务开度减子程序
             if(kdu==0);
              else
      kdu-=1;                // 开度减一
      sd_display();
 void sdchanl(void)interrupt 0          //定义一个中断服务通道转换子程序
           uchar i;
           if(i==10)
               i=0;                    // 通道循环显示
               else
i+=5;
sd_display();
        sd_display()               //手动状态显示子程序
 uint temp;
 uchar j;
            swich(i)
           case 0:
            *xp=1;                通道1 蒸汽显示
            temp=16*kdu;
    temp=temp/99;
    iout=temp+4;
    temp=200*kdu;
    temp=temp/99;
            outdata=temp+50;
            *(xp+1)=kdu/10;
            *(xp+2)=kdu%10;
            *(xp+3)=iout/10
            *(xp+4)=iout%10
             DAC0832A=outdata;
             DAC0832B=50;
             DAC0832C=50;
   break;
            case5:
            *(xp+5)=2;                     通道2 表冷1显示
    temp=8*kdu;
    temp=temp/99;
             iout=temp+4;
     temp=100*kdu;
     temp=temp/99;
             outdata=temp+50;
             *(xp+6)=kdu/10;
             *(xp+7)=kdu%10;
             *(xp+8)=iout/10
             *(xp+9)=iout%10
              DAC0832A=50;
              DAC0832B=outdata;
              DAC0832C=50;
           break;
            case 10:
             *(xp+10)=3;                            通道3,表冷2显示
              temp=8*kdu;
    temp=temp/99;
             iout=temp+12;
    temp=100*kdu;
     temp=temp/99;
             outdata=temp+150
             *(xp+11)=kdu/10;
             *(xp+12)=kdu%10;
             *(xp+13)=iout/10
             *(xp+14)=iout%10
              DAC0832A=50;
              DAC0832B=250;
              DAC0832C=outdata;
      break;
           default:break;
          for(j=0;j<5;j++)        //传送该通道5个字节
               if(((i+j)==1)||((i+j)==6)||((i+j)==11))       //亮红色手动指示灯
               SBUF=(TAB[*(xp+i+j)]|0x80);
               else
               while(TI==0);
               TI=0;
main()
   uchar m,j;
   uint temp;
   TMOD=0x66;        //T0,T1采用计数方式2
    SCON=0x00;         //串口采用同步移位寄存器方式
    IT0=1;             //外部中断采用边沿触发方式
    EA=0;              //关总中断开关
    EX0=1;             //外部中断0允许中断
    ET0=1;             //定时器/计数器0中断允许
    ET1=1;             //定时器/计数器1中断允许
    TL0=0xff;          //T0送初值
    TH0=0xff;
    TL1=0xff;           //T1送初值
    TH1=0xff;
    i=0;
       while(PSW_5==0)          //如果掉电恢复
  read_string(0x01,16,*xp);   //读一组数据
    indata=*(xp+15);
   PSW_5=1;
   if(indata>=50 &&indata<=125)
            temp=temp/75;
            kdu=99-temp;
            temp=200*kdu;
            temp=temp/99;
            outdata=50+temp;
    DAC0832A=outdata;
    DAC0832B=50;
    DAC0832C=50;
        for(j=0;j<5;j++)
       SBUF=TAB[*(xp+j)];
       while(TI==0);
       TI=0;
   if(indata>125&&indata<=150)
    DAC0832A=50;
    DAC0832B=50;
    DAC0832C=50;
        for(j=0;j<5;j++)
        SBUF=TAB[0];
       while(TI==0);
        TI=0;
   if(indata>150&&indata<=200)
      temp=temp/50;
      kdu=temp;
      temp=100*kdu;
      temp=temp/99;
      outdata=temp+50;
      DAC0832A=50;
      DAC0832B=outdata;
      DAC0832C=50;
      for(j=5;j<10;j++)
        SBUF=TAB[*(xp+j)];
        while(TI==0);
        TI=0;
   if(indata>200&&indata<=250)
       temp=temp/50;
       kdu=temp;
       temp=100*kdu;
       temp=temp/99;
       outdata=temp+150;
        DAC0832A=50;
        DAC0832B=250;
        DAC0832C=outdata;
         for(j=10;j<15;j++)
        SBUF=TAB[*(xp+j)];
        while(TI==0);
        TI=0;
       for(m=0;m>10;m++)       //延时10秒并喂狗,之后进入自动程序
       delay(12000);
  while(1)
  while(1)                //自动程序
      for(i=0;i<11;i+5)
       ADC0804= indata;   //启动ad转换
       while(P1_4==1);     //查询转换是否完成
       indata=ADC0804;    //转换完成,读入数据
      *(xp+15)=indata;       //采样数据送ox4f单元
       coolwater2();
         coolwater1();
           newflow();
              if(indata>=50&&indata<=125)
              dream();
       if(indata<50||indata>250)   //如果超出范围,重新读。
       break;
       display();                //显示一组5个数据
       delay(12000);            //循环1秒扫描一次外部4~20ma信号,并循环显示各个通道
       if(A_M==0) break;         //A_M 按下跳出循环,当前通道自动进入手动
     if(A_M==0) break;         //A_M 按下跳出自动进入手动  ,显示当前通道数据
    if(i==15)
      i=10;               //如果i>11,手动后显示通道3的数据
   delay(5000);          //消抖动
   while(A_M==0);
    EA=1;           //开中断
               if((j==1)||(j==6)||(j==11))       //亮红色手动指示灯
               else
               while(TI==0);
               TI=0;
   while(1)            //手动程序
      delay(12000);       //都没按下,喂狗
      if(A_M==0)       //如果按下手动自动切换,则写入数据到e2rom
      break;
            EA=0;
             write_string(0x01,16,*xp) ;  /*将数据写到e2rom片内01H单元*/
      delay(5000);
      while(A_M==0); //写完数据,返回自动程序
请高手看看,我的email :gwei8339@163.com
06-10-16 13:30
全新国内著名厂家高端矢量变频技术,伺服驱动器软件,用于变频伺服生产或者二次开发必备技术,
提升你的产品开发效率,促进你的产品早日上市,争夺市场先机。。
提供完整软件的源码;
可按照客户要求编写修改之后,提供烧写码;
根据客户的要求修改之后,提供带有程序的芯片;
高端1矢量3变频8技2术3来1电3咨7询4伺服6转让4
13-09-09 08:52
