首页 电工技术 电工技术
主题:代替传统锰铜线,台湾产新型低阻值贴片电阻的出现(1mR-1000mR).
点击:866 回复:0
電流感測貼片電阻
Electrical Specifications - Current Sensing Resistor - CS
Package Code (Watts) Temperature Coefficient Tolerance Resistance Range
0402 0.063W ±200ppm/℃ ~±400ppm/℃ 1%, 2%, 5% 0.05 - 1
0603 0.063W ±200ppm/℃ ~±400ppm/℃ 1%, 2%, 5% 0.02 - 1
0805 0.1W ±200ppm/℃ ~±400ppm/℃ 1%, 2%, 5% 0.02 - 1
1206 0.125W ±200ppm/℃ ~±400ppm/℃ 1%, 2%, 5% 0.02 - 1
2010 0.25W ±200ppm/℃ ~±400ppm/℃ 1%, 2%, 5% 0.02 - 1
2512 0.5W ±200ppm/℃ ~±400ppm/℃ 1%, 2%, 5% 0.02 - 1
1225 3W ±200ppm/℃ ~±400ppm/℃ 1%, 2%, 5% 0.005 - 0.2
3720 1W ±150ppm/℃ 1%, 2%, 5% 0.01 - 1
7520 2W ±150ppm/℃ 1%, 2%, 5% 0.001 - 1
Best Regards & Thanks
Anven Long 龍學光
Base Electronic (shenzhen) Company Limited
贝斯電子(深圳)有限公司
Tel: 86-755-27278992  013714301282
Fax:86-755-27278992
E-mail: base008@163.com
http://www.szbase.cn
06-08-26 11:04
