'操作状态CommExit: 0=通讯进行状态,>1=通讯被打断
'通讯状态CommEnd:0=开始发送和等待接收,>1:接收串已结束
'CommError=通讯出错计数
'FxAddress=PLC映象地址计数
'FxString=存放每次PLC返回的应答串
'ErrStr=每串操作的结果提示,"OK" 或 "ERR"
'RowCo1=每次操作结果放在电子表格的填充区域
Public CommExit%, CommEnd%
Public CommError&, FxAddress&
Public FxString$, ErrStr$, RowCo1$
'将CommandButton1改名为Beginning,开始测试
Private Sub Beginning_Click()
Dim c As Range
Dim m1, m2
Dim s$, s1$, MaxLen&
On Error GoTo err1
CommPortOpen 1 '设置串口参数和打开端口
CommExit = 0
CommError = 0
Range("A1") = ""
Range(RowCo1) = ""
FxAddress = 0
RowCo1 = "a2:p257" '操作结果填写在表格的区域
MaxLen = 16 '每次读PLC映象的字节数
'遍历读FX-PLC映象区
For Each c In Range(RowCo1)
'命令串转换
s = "0" & Right("000" & Hex(FxAddress), 4) & Hex(MaxLen)
'指示正在读入的区域
c = Right("000" & Hex(FxAddress), 4) & ":"
'清接收区残余数据,和发命令
s1 = MSComm1.Input
MSComm1.Output = FxChar(s)
FxString = "" '清接收区
CommEnd = 0 '置发送状态
c.Select '焦点指向当前单元格
m1 = Timer + 2 '限定等待时间2秒,超出后转出错并结束
Do While CommExit = 0
m2 = Timer
If m2 > m1 Then
MsgBox "通讯线路出错!请检查线路...", vbCritical
MSComm1.PortOpen = False
Exit Sub
End If
DoEvents '交出VB事件处理控制权
Loop
'通讯被人工打断
If CommExit > 1 Then
MsgBox "通讯被取消...", vbExclamation
Exit Sub
End If
WriteData (FxAddress) '数据写入"PLC数据"工作表
c = c & ErrStr '给出本轮通讯结果状态
FxAddress = FxAddress + MaxLen '映象地址迁移
If FxAddress > &HFFFF& Then
MsgBox "读入工作全部完成!", vbExclamation
Exit For
End If
Next
err1:
End Sub
'将CommandButton2改名为CancelB,打断正在进行的通讯
Private Sub CancelB_Click()
CommExit = 3
End Sub
'在串口中断中接收PLC返回的字串
Private Sub MSComm1_OnComm()
Dim s
Select Case MSComm1.CommEvent
Case comEvReceive
s = MSComm1.Input
Select Case s
Case Chr(6)
CommEnd = 3
Case Chr(21)
CommEnd = 100
End Select
FxString = FxString & s
If Len(FxString) >= 3 Then
If Asc(Right(FxString, 3)) = 3 Then
CommEnd = 5
End If
End If
If CommEnd > 2 Then
If CommEnd = 5 Then
ErrStr = "OK"
Else
ErrStr = "ERR"
CommError = CommError + 1
Range("a1") = "出错计数:" & CommError
End If
CommExit = 1
End If
End Select
End Sub
'将PLC每次返回的数据填写在"PLC数据"工作表里
Private Sub WriteData(n As Long)
Dim i&, j&
Dim s$
Static Row1%, Col1%
With Worksheets("PLC数据")
If n = 0 Then
Row1 = 2
Col1 = 0
.Range(RowCo1) = ""
End If
.Range(Chr(&H61 + Col1) & Row1) = Right("000" & Hex(n), 4) _
& ":" & FxString
If Chr(&H61 + Col1) = "p" Then
Col1 = 0
Row1 = Row1 + 1
Else
Col1 = Col1 + 1
End If
FxString = ""
CommExit = 0
End With
End Sub
'将要发向PLC的命令字串组合:加起始符02h和结束符03h,及累加校验和,返回给调用者
Private Function FxChar$(s$)
Dim m%, n%
Dim s1$
s1 = UCase(s)
For m = 1 To Len(s1)
n = n + Asc(Mid(s1, m, 1))
Next
n = n + 3
FxChar = Chr(2) & s1 & Chr(3) & Right(Hex(n), 2)
End Function
'设置通讯口参数后,打开通讯口
Private Sub CommPortOpen(Port%)
If MSComm1.PortOpen = True Then
End If
MSComm1.CommPort = Port
MSComm1.Settings = "9600,e,7,1"
MSComm1.RTSEnable = True
MSComm1.InputMode = comInputModeText
MSComm1.SThreshold = 1
End Sub
03-08-01 19:46
