首页 现场总线
主题:谁能帮我看看,下面的s7程序是关于ASI通讯的子程序
点击:1558 回复:3
L     #OB82_MDL_ADDR              //Address of the interrupting module
     T     "ASI Data Buffer".laddr
     SET
     =     #t_req
loop: CALL  "RD_REC"                    //SFC 59
      REQ    :=#t_req
      IOID   :=B#16#54                 //Always
      LADDR  :="ASI Data Buffer".laddr
      RECNUM :=B#16#1                  //DS1 = diagnostic information
      RET_VAL:="ASI Data Buffer".retval
      BUSY   :=#t_busy
      RECORD :=P#DB59.DBX10.0 BYTE 11  //DS1 is saved from byte 10 onwards
     CLR
     =     #t_req
     A     #t_busy
     JC    loop
     BE
     CALL  "ASi Driver"                //ASi_CP3422 FUNCTION
      ACT    :=TRUE
      STARTUP:=FALSE                   //ACTIVATE ONCE
      LADDR  :=W#16#100                //CP MODULE ADDRESS - 256 IN HEX
      SEND   :=P#DB13.DBX4.0 BYTE 56   //SEND BUFFER
      RECV   :=P#DB13.DBX62.0 BYTE 56  //RECEIVE BUFFER
      DONE   :=M35.0                   //CALL COMPLETED BIT
      ERROR  :=M35.1                   //CALL STATUS CODE
      STATUS :=MD66
L     W#16#B01                    //set auto-programming on
     T     DB13.DBW    4
     CALL  "ASi Driver"
      ACT    :=TRUE
      STARTUP:=FALSE
      LADDR  :=W#16#100
      SEND   :=P#DB13.DBX4.0 BYTE 2
      RECV   :=P#DB13.DBX62.0 BYTE 14
      DONE   :=M35.0
      ERROR  :=M35.1
      STATUS :=MD66
顺便问一下,怎样编程能使ASI总线系统中有一个模块坏了,换上未编地址的新模块系统能够给它自动编址啊
06-03-23 20:46
有兴趣研究请我和联系,QQ103595593,我有ASI的程序
06-07-14 12:51
我不太明白最后的两段
call "ASI Driver"
看着基本一样啊,为什么要重复写呢?
06-07-20 16:30
帮顶
06-07-20 16:54
