首页 电脑编程
主题:请教VB通讯?
点击:3478 回复:10
在串口通讯中,是不是可以用SEND发送指令,而不必用MSCOMM指令?有不有这方面的例子
06-03-11 19:29
不是吧,不能这么发送吧.
06-03-11 21:09
你用api还是串口组件?
06-03-11 21:16
mscomm是microsoft推出一个针对串口操作的一个组件,也就是一个类,使用的时候生成这个类的实例,然后使用类中的方法发送或者接受数据.
06-03-12 00:45
下面的代码可能是用来串口通讯的,是一个模块,看了很久,不知道具体是什么意思,用了哪些函数,每个函数是什么意思。不好意思,是刚接触,希望大家不吝指教一二,在此不胜感激
Public m_devtype As Long
Public m_connect As Byte
Public m_devind As Long
Public m_cannum As Long
Public m_idx As String
Public m_passcode As String
Public UserName As String
Public strpass(6) As String
Public m_modeselc As String
Public m_NODEID As String
Public m_btnNODE As Boolean
Public m_Timing0 As String
Public m_Timing1 As String
Declare Function VCI_OpenDevice Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal Reserved As Long) As Long
Declare Function VCI_CloseDevice Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long) As Long
Declare Function VCI_InitCAN Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long, ByRef InitConfig As VCI_INIT_CONFIG) As Long
Declare Function VCI_ReadBoardInfo Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByRef info As VCI_BOARD_INFO) As Long
Declare Function VCI_ReadErrInfo Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long, ByRef ErrInfo As VCI_ERR_INFO) As Long
Declare Function VCI_ReadCANStatus Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long, ByRef CANStatus As VCI_CAN_STATUS) As Long
Declare Function VCI_GetReference Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long, ByVal RefType As Long, ByRef data As Any) As Long
Declare Function VCI_SetReference Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long, ByVal RefType As Long, ByRef data As Any) As Long
Declare Function VCI_GetReceiveNum Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long) As Long
Declare Function VCI_ClearBuffer Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long) As Long
Declare Function VCI_StartCAN Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long) As Long
Declare Function VCI_ResetCAN Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long) As Long
Declare Function VCI_Transmit Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long, ByRef Send As VCI_CAN_OBJ, ByVal length As Long) As Long
Declare Function VCI_Receive Lib "ControlCAN.dll" (ByVal DeviceType As Long, ByVal DeviceInd As Long, ByVal CANInd As Long, ByRef Receive As VCI_CAN_OBJ, ByVal length As Long, ByVal WaitTime As Long) As Long
'定义需要用到的数据结构
Public Type VCI_BOARD_INFO
   hw_Version As Integer
   fw_Version As Integer
   dr_Version As Integer
   in_Version As Integer
   irq_num As Integer
   can_num As Byte
   str_Serial_Num(19) As Byte
   str_hw_Type(39) As Byte
   Reserved(3) As Integer
End Type
Public Type VCI_CAN_OBJ
   ID As Long
   TimeStamp As Long
   TimeFlag As Byte
   SendType As Byte
   RemoteFlag As Byte
   ExternFlag As Byte
   DataLen As Byte
   data(7) As Byte
   Reserved(2) As Byte
End Type
Public Type VCI_CAN_STATUS
   ErrInterrupt As Byte
   regMode As Byte
   regStatus As Byte
   regALCapture As Byte
   regECCapture As Byte
   regEWLimit As Byte
   regRECounter As Byte
   regTECounter As Byte
   Reserved As Long
End Type
Public Type VCI_ERR_INFO
   ErrCode As Long
   Passive_ErrData(2) As Byte
   ArLost_ErrData As Byte
End Type
Public Type VCI_INIT_CONFIG
   AccCode As Long
   AccMask As Long
   Reserved As Long
   Filter As Byte
   Timing0 As Byte
   Timing1 As Byte
   Mode As Byte
End Type
Public Function ConnectString() As String
  Dim strAppPath As String
  strAppPath = App.Path
  If Right(strAppPath, 1) <> "\" Then
      strAppPath = strAppPath & "\"
  End If
  strAppPath = strAppPath & "Data\object.mdb"
  ConnectString = "DRIVER=Microsoft Access Driver (*.mdb);DBQ=" & strAppPath & ";PWD=phase.com.cn" '& strAppPath &
End Function
Public Function ExecuteSQL(ByVal SQL As String, MsgString As String) As ADODB.Recordset
  Dim cnn As ADODB.Connection
  Dim rst As ADODB.Recordset
  Dim sTokens() As String
  On Error GoTo ExecuteSQL_Error
  sTokens = Split(SQL)
  Set cnn = New ADODB.Connection
  cnn.Open ConnectString
  If InStr("INSERT,DELETE,UPDATE", UCase$(sTokens(0))) Then
     cnn.Execute SQL
     MsgString = sTokens(0) & " query successful"
  Else
     Set rst = New ADODB.Recordset
     rst.Open Trim$(SQL), cnn, adOpenKeyset, adLockOptimistic
     Set ExecuteSQL = rst
     MsgString = "查询到" & rst.RecordCount & " 条记录 "
  End If
ExecuteSQL_Exit:
  Set rst = Nothing
  Set cnn = Nothing
  Exit Function
ExecuteSQL_Error:
  MsgString = "查询错误: " & Err.Description
  Resume ExecuteSQL_Exit
End Function
06-03-13 11:19
请问一下,frameinfo是不是VB的一个命令?
06-03-13 16:42
用API函数是不是可以进行串口通讯,请问一下API函数的用法?
06-03-14 08:54
这是一个安装在计算内的接口卡吧(我猜是CAN总线接口卡)? 人家提供了驱动程序给你了,参照它的例程做就好了!把动态库的接口函数研究研究吧!
06-03-14 10:51
xiexie,没有接口卡,但用的是CANOPEN通讯,是用232接口转485通讯,同时控制3台伺服电机,是自已编了一个API函数,做为公用模块。NND,看了半天,没看到这个动态库“ControlCAN.dll”,因为编的人已走了,只留下源代码,也没人说过这个动态库的用法,要怎么去把这个动态库提出来,并反编出来。郁闷中
06-03-14 13:25
另外,因我这个源代码是从其他电脑拷出来的,在程序中没有这个动态库文件,不知还能不能进行串口通讯了?
06-03-14 13:41
上一页下一页
