首页 安防智能
主题:供应三菱全部FX系列可编程控制器(PLC)
点击:1911 回复:1
价格面议,量大从优。
深圳市菱泰兴科技有限公司
电话:0755-26444316
传真:0755-26484316
联系人:刘二文
手机:13267152530
邮件:chenxinzhou@szautomation.com
E-20TP-E-SET0 PROGRAMMER FOR FX2N-10GM AND FX2N-20GM 5,160.00
F2-232CAB-1 TRANSFER CABLE BETWEEN COMPUTER AND DATA ACCESS UNIT 1,320.00
F2-40BL BACKUP BATTERY FOR FX CPU 530.00
F2-720RSV RESOLVER 3,360.00
F2-RS-5CAB EXTENSION CABLE FOR FX2N-RS-5CAB 590.00
FX0N-16EX EXT. UNIT WITH 16 INPUT 1,120.00
FX0N-16EYR EXT. UNIT WITH 16 RELAY OUTPUTS 1,270.00
FX0N-16EYT EXT. UNIT WITH 16 TRANSISTOR OUTPUTS 1,270.00
FX0N-16NT MELSECNET/MINI COMMUNICATION UNIT 2,330.00
FX0N-232ADP RS232 COMMUNICATION MODULE 1,140.00
FX0N-24MR-001 BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 3,210.00
FX0N-24MR-D BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 3,050.00
FX0N-24MT BASE UNIT WITH 14 INPUTS/10 TRANSISTOR OUTPUTS 3,470.00
FX0N-24MT-D BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 3,210.00
FX0N-32NT-DP PROFIBUS-DP INTERFACE UNIT 2,420.00
FX0N-3A 2 CHANNEL A/D, 1 CHANNEL D/A 2,330.00
FX0N-40ER EXT. UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 2,980.00
FX0N-40ET EXT. UNIT WITH 24 INPUTS/16 TRANSISTOR OUTPUTS 2,980.00
FX0N-40MR-001 BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 4,300.00
FX0N-40MR-D BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 4,090.00
FX0N-40MT BASE UNIT WITH 24 INPUTS/16 TRANSISTOR OUTPUTS 4,520.00
FX0N-40MT-D BASE UNIT WITH 24 INPUTS/16 TRANSISTOR OUTPUTS 4,300.00
FX0N-485ADP RS485 COMMUNICATION MODULE WITH MULTI-DROP FUNCTION 1,430.00
FX0N-60MR-001 BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS 5,010.00
FX0N-60MR-D BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS 4,590.00
FX0N-60MT BASE UNIT WITH 36 INPUTS/24 TRANSISTOR OUTPUTS 5,010.00
FX0N-60MT-D BASE UNIT WITH 36 INPUTS/24 TRANSISTOR OUTPUTS 4,770.00
FX0N-65EC EXTENSION CABLE 350.00
FX0N-8ER EXT. UNIT WITH 4 INPUTS/4 RELAY OUTPUTS 900.00
FX0N-8EX EXT. UNIT WITH 8 INPUTS 750.00
FX0N-8EYR EXT. UNIT WITH 8 RELAY OUTPUTS 900.00
FX0N-8EYT EXT. UNIT WITH 8 TRANSISTOR OUTPUTS 900.00
FX0S-10MR-001 BASE UNIT WITH 6 INPUTS/4 RELAY OUTPUTS 1,610.00
