Dim IntMin As Integer
Dim IntSec As Integer
Private Sub Form_Load()
Timer1.Enabled = True
Timer1.Interval = 400
Timer2.Enabled = False
Timer2.Interval = 1000
End Sub
Private Sub Timer1_Timer()
IntMin = Val(Mid(Format(Time, "hh:mm:ss"), 4, 2))
IntSec = Val(Mid(Format(Time, "hh:mm:ss"), 7, 2))
If IntSec = 0 And IntMin Mod 5 = 0 Then
'record
'date=txtdate
'time=txttime
'voltage=txtvoltage
'current=txtcurrent
Timer1.Enabled = False
Timer2.Enabled = True
End If
End Sub
Private Sub Timer2_Timer()
'open db,table;record addnew,record update;close table,db
End Sub
06-02-21 08:24
