首页 PLC论坛 西门子SIEMENS
主题:小弟,刚出道,大侠快来帮帮忙吧!!!!
点击:1176 回复:1
我在各位大侠的指点下安装wincc就差最后一步了,出现如下问题,请各位帮忙啊
MS Security Patch is not installed on this system.
For this WinCC Version, the following software is required:
    WindowsXP SP 2 KB319740
Please run the installation of MS-Security Patch from your MS Tools - CD.
Operation of WinCC under Windows XP SP2 has been released for WinCC clients with deactivated firewall only.
You must deactivate the firewall manually.
05-12-07 20:35
去微软下载Q319740补丁
05-12-21 09:59
