最后修改:2024/3/22 9:24:57
点击:627 回复:5
引用 yjuwlufg7700 在 2024/3/22 20:25:15 发言【内容省略】
Please go to the parameters to see the DC bus voltage. If there is no DC bus voltage, it means you have not faked the DC bus signal. Even if there is no dc bus voltage, the circuit board will still be normal but it will not do anything, only when you short circuit the input phase loss optocoupler, will the circuit board actually work.
