首页 PLC论坛 西门子SIEMENS
主题:通快的数控激光切割MMC进程异常结束,求解
点击:471 回复:0
Application: Mmc200x.exe
Framework Version: v
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Net.Sockets.SocketException
Server stack trace:
  at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
  at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
  at System.Runtime.Remoting.Channels.RemoteConnection.CreateNewSocket(EndPoint ipEndPoint)
  at System.Runtime.Remoting.Channels.RemoteConnection.CreateNewSocket()
  at System.Runtime.Remoting.Channels.RemoteConnection.GetSocket()
  at System.Runtime.Remoting.Channels.SocketCache.GetSocket(String machinePortAndSid, Boolean openNew)
  at System.Runtime.Remoting.Channels.Tcp.TcpClientTransportSink.SendRequestWithRetry(IMessage msg, ITransportHeaders requestHeaders, Stream requestStream)
  at System.Runtime.Remoting.Channels.Tcp.TcpClientTransportSink.ProcessMessage(IMessage msg, ITransportHeaders requestHeaders, Stream requestStream, ITransportHeaders& responseHeaders, Stream& responseStream)
  at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg)
  at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(System.Runtime.Remoting.Messaging.IMessage, System.Runtime.Remoting.Messaging.IMessage)
  at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(System.Runtime.Remoting.Proxies.MessageData ByRef, Int32)
  at Trumpf.Production3D.Interface.Status.TiProductionStatusServer.RegisterClient(Trumpf.Production3D.Interface.Status.TiProductionStatusServerCb)
  at Trumpf.Production3D.Client.Logic.TcProductionStatusClientLogic.Trumpf.Production3D.Client.Interface.TiProductionStatusClientLogic.RegisterGui(Trumpf.Production3D.Client.Interface.TiProductionStatusClientLogicCb)
  at Trumpf.Production3D.Client.Gui.TcFormProductionStatus.BindControls()
  at Trumpf.Touch.Forms.TcFormBase.SetupData()
  at Trumpf.Touch.Forms.Controls.TcFormTabPage.MakeVisible()
  at Trumpf.Touch.Forms.Controls.TcTabControl.OnTabSelectionChanged(Trumpf.Touch.Forms.Controls.TabSelectionEventArgs)
  at Trumpf.Touch.Forms.Controls.TcTabControl.set_SelectedIndex(Int32)
  at Trumpf.Touch.Forms.Controls.TcTabControl.OnTabItemClicked(Int32)
  at Trumpf.Touch.Forms.Controls.TcTabControl.OnMouseUp(System.Windows.Forms.MouseEventArgs)
  at System.Windows.Forms.Control.WmMouseUp(System.Windows.Forms.Message ByRef, System.Windows.Forms.MouseButtons, Int32)
  at System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef)
  at System.Windows.Forms.Control+ControlNativeWindow.OnMessage(System.Windows.Forms.Message ByRef)
  at System.Windows.Forms.Control+ControlNativeWindow.WndProc(System.Windows.Forms.Message ByRef)
  at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr, Int32, IntPtr, IntPtr)
  at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef)
  at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
  at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext)
  at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext)
  at System.Windows.Forms.Application.Run(System.Windows.Forms.Form)
  at Trumpf.Sys.TouchBaseApplication.TcGuiApplication.Run()
  at Trumpf.Sys.TouchBaseApplication.TcMainProgram.Main()
21-10-12 21:58
