首页 PLC论坛 施耐德电气PLC
主题:请教somachine仿真运行出*EXCEPTION*例外故障
点击:1495 回复:3
没错, 贝加莱标准化项目已经完成了。 也已经写了文章+总结
《【万泉河】贝加莱PLC标准化项目开发,一周完成》
先发在其他空间了,本站稍后发。
然后马不停蹄又搞施耐德了。
然而一上来就遇到个弼马温。写个最简单的累加程序,下载到仿真去, 多则一个小时,短则几分钟,一会儿就跳掉了。 截图在最后。 有要源程序帮忙分析的,留言稍后想办法传上。
有对施耐德SO系统熟悉的大神麻烦解答一下. 杠精请绕路
   *EXCEPTION* Watchdog Sim.MyController.Application MAST
   application=Sim.MyController.Application, dataid{d464fbcf-00000000-00000000-00000000}
   application=Sim.MyController.Application, codeid={b0dd5796-00000000-00000000-00000000}
   Application Sim.MyController.Application loaded [Download]
   ServerAppHandleRequest returned 28
   Online change denied. Application Sim.MyController.Application is in exception state!
   *EXCEPTION* Omitted cycle Watchdog Sim.MyController.Application MAST
   application=Sim.MyController.Application, dataid{b7969497-00000000-00000000-00000000}
   application=Sim.MyController.Application, codeid={4d3c60bf-00000000-00000000-00000000}
   application=Sim.MyController.Application, codeid={2b853a84-00000000-00000000-00000000}
   Retains are not stored for Sim.MyController.Application
   Setting router 0 address to (0000:4001)
   CODESYS Control ready
   Setting router 0 address to (0001)
   Local address (BlkDrvShm) set to 1
   Network interface BlkDrvShm registered
   Listening for connections on SharedMemory: SimulationGWDirectCallShm3428
   Network interface BlkDrvTcp registered
   Client is disabled
   Local network address: 127.0.0.1
   Only allowed peer ip address: 127.0.0.1
   Local ip address of the only used network adapter: 127.0.0.1
   8 channels available, each of the size 100000 Bytes
   Running as network client
   Running as network server
21-08-16 20:52
是不是某段程序执行时间太长触发看门狗了?
21-08-17 08:01
只有一句程序, A=A+1
21-08-17 08:27
INT 超限了!!!
21-09-16 13:59
