首页 变频器维修
主题:安邦信ABM-P7变频器故障求助
点击:1301 回复:7
各位师傅好,向您请教一下,安邦信AMB-P7-075变频器的这两个电阻的线都接在哪里,有知道的师傅指点一下。谢谢了。
21-08-07 11:31
变频器侧面的两个电阻。只知道两个30K的电阻一个蓝色的接-极,红的接+极,白的和另一个电阻不知道接那里了,有知道的师傅指点一下,谢谢了
21-08-07 14:33
data:image/jpeg;base64,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
21-08-09 09:32
不知道怎么发图片,弄成这样
21-08-09 09:39
21-08-09 09:40
就是这两根线不知道接哪里了
21-08-09 09:41
鬼知道那是什么线,这种造型的100欧以下是充电电阻,30K是均压电阻!均压电阻有的是2个合成在一起,3根线那个就是!
最后修改:2021/8/9 9:53:30
21-08-09 09:47
变频器在维修之前,必须拍照保存,在维修后复原电路时必须对应拍照的图片,才能给变频器上电,这是维修变频器必须流程!这次遇到困难,下次就知道了,这也是经验!
21-08-09 15:42
