首页 PLC论坛 德嘉工控
主题:How to use the S7-1200 as a client and connect it with modbus RTU instrument
点击:403 回复:0
Modbustcp/ModbusRTU converter which developed and produced by Dalian Winbest INT.
This product is used for WinCC, Kingview, Siemens S7-200smart, S7-1200, S7-1500 PLC to connect Modbus instruments or other equipments through the method with converting ModbusRTU into Modbus TCP.
21-01-26 14:19
