请参阅《SoMachineV4.3Patch2-ReleaseNotes.EN.rtf》P5:
4. Installation
The Patch 2 is delivered as a container file in SECO format.
Use the SoMachine Configuration Manager (SCM) to install this Patch.
In Windows Explorer, double-click the SECO file delivered through this Patch, which will start SCM and the installation.
Alternatively, you can start SCM manually, change to the tab "Add-Ons/Patches" and choose "From File >" to open the delivered SECO file.
The installation of the Patch 2 requires administrator privileges to start.
翻译如下:
4. 安装
补丁2以SECO格式作为容器文件交付。
使用SoMachine Configuration Manager(SCM)安装此修补程序。
在Windows资源管理器中,双击通过此修补程序传递的SECO文件,将启动SCM和安装。
或者,您可以手动启动SCM,切换到“Add-Ons/Patches”选项卡,然后选择“From File>”打开已交付的SECO文件。
安装修补程序2需要管理员权限才能启动。
21-01-26 22:10
