新年第一帖,分享英语,要提高英语的来顶贴了,同楼主一起加加油
1. PLC 可编程控制器
2. absolute 绝对
3. absoluteoutput 绝对最大输出
4. actuator 执行器
5. against 对比
6. allocate 分配
7. alter 改变 、修改
8. ambient 环境 、周围 ambient operating temperature
9. analog 模拟 analogoutput
10. analysis 分析 thecollection an and analysis of data
12. applicable 可用 the applicableCPU for the module
13. assign 分配
14. back up battey 备用电池
15. barcode reader/ID 条形码阅读器
16. base unit 主基板
17. baud 波特 [bo:d]
18. beforehand 事先
19. binary 二进制
20. buffer memory 缓冲存储器
21. bus 总线
22. case 外壳 do notremove the module's print board from the case
23. characteristic 特征 I/Ocharacterristic
24. check 校验 the datalink status canbe checked
25. child-station 子站
26. common terminal 公共端
27. compatible 兼容 compatiblewith the MODBUS protocol
28. compound 混合 compoundsystem communication [`compaund]
29. condensation 结露
30. condition 条件 conditionsetting
31. conductive 导电 conductivemetal picees
32. configuration 组态 systemconfiguration
33. configure 组态
34. confirm 确认 how toconfirm the operation of the module
35. consumption 消耗 currentconsumption
36. content 目录
37. control level 控制级
38. convenient 方便 moreconvenient and easy-to-use
39. conventionaly 传统 whichconventionaly has been used
40. conversion 转换 Analog-Digital conversion module
41. converter 转换器
42. conveyor 传送 conveyorline
43. corrosive 腐蚀 corrosivegas
44. countermeasure 对策countermeasure for mis-inpute
45. cutoff 切断
46. debug 调试 isrecommended before debugging
47. dedicated 屏蔽 cc-linkdedicated cable
48. dedicated 专用 dedicatedtransmission protocol
49. default value 缺省值
50. define 解释、阐明 Offset value and gain value are defined as follow. [di`fain]
51. design 设计 design asystem
52. device level 现场级
53. diagnosis 诊断 diagnosisfunction
54. digital 数字 digitalinpute
55. DIN rail 导轨
56. diverse 不同的各种各样的
57. download 下载
58. duplicate 完全一样
59. dust 灰尘
60. eliminate 免得[i`limineit]
61. enterprise level 管理级
62. erase 清除
63. exceed 超出 The numberadmitted must not exceed 200
64. execute 执行 date linkis executed using these parameters
65. expand 扩展 can beeapanded up to 255 networks
66. faulty 故 障站
67. field bus 现场总线
68. fix 固定
69. flexibly 灵活的 to supporta variety systerm flexibly
70. flow 流量
71. format 格式transmission format [`fo:maet]
72. fuse 融丝
73. graph 图标 坐标图曲线图 voltage output characterristicgraph
74. guaranteed 担保 nomaloperration cannot be guaranteed
75. handle 处理
76. hardware manual 硬件手册
77. hint 提示 programminghints
78. humidity 湿度 ambientoperating humdlity
79. individual 独立的
80. inductance 电感 inductanceload
81. initiate 实施 发起 can be initiate by a computer [i`nifieit]
82. input 输入
83. input point 输入点数
84. install 安装
85. instruction 指令 the FROMinstruction
86. insulation 隔离 form rubberprovides good insulation [,insju`leifn]
87. interface 接口
88.interlocking 互锁 can be usedfor sequence program interlocking
89. internal external 内部 外部 internal connection
90. interrupt 中断 excute aninterrupt processing
91. invalid 无效 errorinvalid station function
92. magnetic 有磁性的 magneticfields [maeg`netik]
93. main circuit 主回路
94. malfunction 故障 causesystem malfunction
95. mandatory 强制
96. mantenance 维护 maintenancecosts are reduced
97. manual 手册 User'Manual
98. mechanical 机械 michanicallife机械寿命
99. module 模块 mount orremove the module [`modju:l]
100. momentary power failure 瞬时断电
101. monitor 监视
102. mount 固定 mount orremove the module
103. multiple 多样 mutipleremote i/o modules
104. negative 负
105. observation 观察
106. occupy 占用 occupies 1station
107. occur 发生
108. offline 离线 offlinetest
109. offset gain 偏置增益
110. oil mist 油雾
112. optical loop 光缆回路
113. optimum 最佳的 optimumcontrol
114. output 输出
115. overall 总的 overalldistance
116. overview 总揽communication overview
117. parameter 参数
118. path 路径transmission path
119. per network 网路
120. perform 进行 normal datalink cannot be performed
121. performance specifations 性能规格
122. peripheral 外围 Whenutilizing peripheral device to assign I/O number.
123. phase 相 swith offall phases of the power supply [`feiz]
124. point 要点
125. port 接口 Rs232c port
126. positive 正
127. power line 电源线
128. power on/off 上电断电
129. precaution 注意事项precaution when configuing system
130. print board 印刷电路板
131. procedure 过程 follow theprocedure
132. programing interface 编程口
133. protocol 协议 protocolcommunication issues
134. range 范围
135. rated input voltage 额定输入电压
136. ratio 比率
137. recommend 建议 isrecommended before debugging
138. reduce 减少 the numberof steps in operation program can be reduced
139. refer to 参照 refer toChapter 6
140. register 数据寄存器
141. relay 继电器 [`ri:lei]
142. remote I/O 远程网络
143. reserved station 预留主站
144. resistor 电阻 resistorload 阻性负载 terminating resistor
145. resolution 分解,解析 nMaximum resolution 最大分辨率
146. restriction 限制 norestriction [ri`strikfn]
147. retry 重试
148. scan 扫描 link scan
149. screw 螺丝 Teminal-block screw
150. seamless network 无缝网络
151. sequence programme 顺控程序
152. serial communications module 串口模块
153. series 系列
154. servo 伺服
155. short 短路
156. signal 信号
157. sink 漏极 sink commen
158. slot 槽
159. soures 源极 sourescommen
160. specifications 特性 inputmodules specifications
161. stabilized power supply 稳压电源
162. standby master station 备用主站
163. start up 起动
164. status 状态 data linkstatus
165. step drive 步进
166. storage 存储 storagearea
167. store 存储
168. switch off 关断 swith offall phases of the power supply
169. swith 开关
170. table 表格
171. transfer 传输
172. transistor 晶体管
173. transmission speed 传输速度
174. transmit 传送 data istransmitted in unchanged code
175. triac 双端三相可控硅开关
176. troubleshooting 故障处理
177. unuseble 不可以使用
178. upload 上传
179. utilize 利用 Whenutilizing peripheral device to assign I/O number.
180. verify 校验 verify theset parameter contents
181. voltage 电压 highvoltage
182. watchdog 看门狗
183. width 范围 it willvary in the width of [widθ]
184. wire chips 线头
