首页 运动控制 运动控制
主题:Rexroth伺服驱动器报代码F281故障,该伺服驱动器还有维修的价值么?
点击:1306 回复:2
最后修改:2019/4/4 10:45:21
19-04-04 10:29
F281 Mains fault
Cause:
The power supply voltage was not present during operation for at least 3
power periods. As a result, the drive controller was brought to a standstill
according to the set error response.
Remedy:
Check the power supply connection according to the project planning
specifications
很可能是电源问题。
19-04-05 01:55
力士乐的任何设备都有维修的价值
19-08-13 11:09
