首页 PLC论坛 西门子SIEMENS
主题:[求助]STEP7 V5.2安装后程序不能正常保存!
点击:2739 回复:2
我的操作系统是win98,是不是要用2k?请大家帮忙诊断诊断是什么毛病。
出错信息
1.安装时的警告(Warning 1909)
Could not create shortcut lista di compatibilita.lnk.
verify that the destination folder exists and that you
can access it.
安装目录
D:\Program Files\Siemens\Step7
2.启动计算机时弹出信息框
s7ubTskb
Testing registration...  Key HKEY_LOCAL_MACHINE\SOFTWARE\SIEMENS\AUTSW\Global\SharedPath
< OK
Comparing registration with path... D:\Program Files\Common Files\Siemens\SqlanyPath in AUTOEXEC.BAT does not match registry.
< Not OK
Testing SET SQLANY in AUTOEXEC.BAT...
SET SQLANY
< Not OK
Testing path for SQL Anywhere DLL... dbl50t.dll
< Not OK
Testing path for SQL Anywhere DLL... wl50ent.dll
< Not OK
Searching for S7ubtoox...
< OK
Installed Protocols..TCPIP installedIPX installed
< OK
Testing Winsock DLL...Found Winsock Version 2
< OK
Testing ODBC configuration...
< Not OK
3、点击桌面右下角的标图
simatic workstation
找不到所需的DLL文件
DBLIB7.DLL
实际上找得到这个文件
D:\Program Files\Common Files\Siemens\SQLANY\DBLIB7.DLL
4、打开s7时出错(257:5)
One or more objects of a type cannot be represented.
Unable to load the server ''s7utomtx.dll'' for
_S7UT_LEXICON_CONTAINER_CT  objects.
Make sure that the required optional packages are installed.
5、无法保存出错Close(30:6)
The block FC1 was changed.
Do you want to save the block?
点击保存后,关闭程序,又出现这个对话框。
6、刚安装后是正常。用几次后就不正常了。重装后,恢复正常。关机重启几次又不正常了。
最后修改:2005-7-20 0:55:03
05-07-20 00:54
是不是必须安装SQLanywhere?
05-07-20 00:58
哪位高手帮帮忙啊!!
05-07-22 15:54
