首页 变频器维修
主题:Help me. Inverter powtran pi9200 display cof
点击:1631 回复:19
17-09-07 15:39
普传啥意思
17-09-07 17:33
MR. 楼主,频器出现这个代码COF怎么处理?是吧?
17-09-07 18:03
你是外国人吗?如果不是的话请讲中文
17-09-07 18:38
PI9000 can provide effective protection. If an abnormal fault occurs, the protection function will be called, the inverter will stop output, the inverter fault relay contact will be activated, and the fault code will be displayed on the display panel of the inverter.
17-09-07 23:27
扯,不识中文还能准确的找到此论坛,在变频器维修里发图片?
17-09-08 08:25
The 4F already give you the fault code explanation,main problem is the communication,please check the connection between the control panel and inverter.
17-09-08 10:46
看名字好像是韩国?朝鲜?
17-09-08 10:59
越南胡志明
17-09-08 14:23
是。我来自viet nam你可以帮我吗。谢谢
17-09-11 23:19
上一页下一页
