首页 电脑编程
主题:C#打印问题 求助各位
点击:758 回复:1
怎么实现 打印已有的excel表格?  PrintOut?  各位有什么好方法吗?初学一脸懵  能说说具体的实现方法吗
16-11-24 10:56
引用 伊翱 在 2016/11/24 10:56:02 发言【内容省略】
using System;
using System.Drawing.Printing;
using System.Windows.Forms;
using Spire.Xls;
namespace Print_Excel_in_csharp
   public partial class Form1 : Form
       public Form1()
           InitializeComponent();
       private void button1_Click(object sender, EventArgs e)
           Workbook workbook = new Workbook();
           workbook.LoadFromFile("Sample.xlsx");
           Worksheet sheet = workbook.Worksheets[0];
           sheet.PageSetup.PrintArea = "A7:T8";
           sheet.PageSetup.PrintTitleRows = "$1:$1";
           sheet.PageSetup.FitToPagesWide = 1;
           sheet.PageSetup.FitToPagesTall = 1;
           //sheet.PageSetup.Orientation = PageOrientationType.Landscape;
           //sheet.PageSetup.PaperSize = PaperSizeType.PaperA3;
           PrintDialog dialog = new PrintDialog();
           dialog.AllowPrintToFile = true;
           dialog.AllowCurrentPage = true;
           dialog.AllowSomePages = true;
           dialog.AllowSelection = true;
           dialog.UseEXDialog = true;
           dialog.PrinterSettings.Duplex = Duplex.Simplex;
           dialog.PrinterSettings.FromPage = 0;
           dialog.PrinterSettings.ToPage = 8;
           dialog.PrinterSettings.PrintRange = PrintRange.SomePages;
           workbook.PrintDialog = dialog;
           PrintDocument pd = workbook.PrintDocument;
           if (dialog.ShowDialog() == DialogResult.OK)
           { pd.Print(); }
原文请阅读:http://www.cnblogs.com/Yesi/p/5505756.html
最后修改:2016/11/24 12:20:36
16-11-24 12:19
