首页 PLC论坛 PLC论坛
主题:译码指令
点击:553 回复:3
DECO D0 D10 k4谁能拿它当例子给讲讲,谢谢
16-06-21 16:42
DECB(BINARY DECODING)
Function
DECB decodes one, two, or four-byte binary code data. When one of the specified eight consecutive numbers matches the code data, a logical high value (value 1) is set in the output data bit which corresponds to the specified number. When these numbers do not match, a logical low value (value 0) is set.
Use this instruction for decoding data of the M or T function.
In PMC-SB5/SB6/SB7 for Series 16i/160i/18i/180i/Power Mate i and PMC-SA5 for Series 21i/210i, the setting of the format specification parameter is extended. With this setting, DECB can decode multiple (8* n) bytes.
16-06-21 19:28
看下三菱的编程手册,上面有详细解释。
16-06-22 09:39
楼主是不是完全不看编程手册的呀?
16-06-22 19:56
