首页 单片机论坛
主题:关于AVR单片机的问题4
点击:430 回复:0
各位高手,小弟正在基于AVR单片机开发一款智能小车,遇到“LCD无法显示速度数据”,调试了一下,屏蔽了大部分代码保留了对LCD操作的代码,当执行到“LCD_RS_PORT&=~LCD_RS;”这一句时,测量了RS管脚的电平,发现RS管脚电平并未拉低,仍然为高电平。请教其中的原因。谢谢。部分代码如下:
void LCD_init(void)
 LCD_DATA_DDR|=LCD_DATA;
 LCD_EN_DDR|=LCD_EN;
 LCD_RS_DDR|=LCD_RS;
 LCD_RW_DDR|=LCD_RW;
 LCD_RW_PORT&=~LCD_RW;        //RW=0
 LCD_write_command(0x28);
 #if 0
 LCD_en_write();
 delay_nus(40);
 LCD_write_command(0x0c);
 LCD_write_command(0x01);
 delay_nms(2);
 #endif
void init_devices(void)
   //stop errant interrupts until set up
   CLI(); //disable all interrupts
   port_init();
   timer0_init();
   LCD_init();
   time1_init();
time2_init();
INT_init();
   TIMSK |= BIT(2);
TIMSK |= BIT(0);
TIMSK |= BIT(6);
SEI(); //re-enable interrupts
//all peripherals are now initialized
void main(void)
   int counter = 0;
int i;
int stop_count = 0;
//MCUCSR &= ~BIT(4);
MCUCSR |= BIT(7);
MCUCSR |= BIT(7);
//vInitEeprom();
uart0_init();
   init_devices();
   //EECR |= BIT(EERIE);
DUTY1=50;
   DUTY2=50;
   addr = 1;
while (1)
   delay_ms (10);
14-11-02 10:05
